Hi! I know this isn't Flitetest's scratch build, but I was looking for build thread of a simple quad for a long time, so I decided to do it myself.
Here I'm going to show you complete build of my quad-copter (simple quad)
Note: I'm just a 14 years old boy, so don't judge me if you find any mistakes.
Here is a list of the components and parts I've used:
Motor: 4 hexTronik DT750 Brushless Outrunner 750kv
ESC: 4 TURNIGY Plush 25amp Speed Controller
Control board: 1 Hobbyking KK2.0 Multi-rotor LCD Flight Control Board
1 TURNIGY BESC Programming Card
2 PolyMax 3.5mm Gold Connectors 10 PAIRS
1 10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Red)
1 10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Black)
1 On Board Lipoly Low Voltage Alarm (2s~4s)
1 XT60 to 4 X 3.5mm power breakout cable
1 MPX Connector Male/Female (10pairs/set)
1 10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set)
Note: When I was ordering at HK they didn't have it in stock so I soldered my own cables from Servo Terminals and 15CM Servo Lead Extension.
For battery I suggest 2200mAh 25C Turnigy battery. I already have some 3 cell batteries lying around so I haven't order new ones.
Later I realized that somehow I haven't ordered breakout cable, so I had to solder it by myself. I used multiplex connectors instead of XT60's.
Frame Building:
To make frame as simple as possible I decided to do it from 4mm plywood and 10mm (0.393 inch) square spruce sticks, which could be found in any DIY store.
First cut two arms on length 60cm (23.62) with handsaw. At half (30cm) measure 5mm on each side and cut 5mm deep slot. Make sure that both together fit perfect. If not sand edges until it is OK.
Then cut two square pieces out of 4mm plywood with dimensions 12cm*12cm (4.72*4.72). These will be used for reinforcement.
Now when you got all parts cut out and they fit together perfectly it's time to glue all parts together. I use wood glue, because all parts are wooden and it allows mistakes (you got a lot of time to make sure that arms are perpendicular).
First glue arms and again make sure it's perpendicular.
Wait for about 10 minutes that glue barely sticks and glue your upper plate on. Try to fix corners of the plate in the middle of the sticks.
Make sure it's still perpendicular.
If it isn't try hard to fix that problem.
After about 10 minutes glue the other plate on.
Well our frame is done.
Now it's time to paint your frame (to look better and protect wood from water and dirt) if you want. I decided to paint mine white, because I had some white acrylic paint lying around from other projects.
The total weight of unpainted frame should be somewhere around 110g.
That is 3.8 ounces.
hexTronik DT750 Brushless Outrunner 750kv |
TURNIGY Plush 25amp Speed Controller |
Hex locknuts M |
Installation of motors:
I started with mounting DT750 mountings on arms. I used 4mm zip-ties, as screws don't like vibrations and DT750's have pretty unusual mountings. If you choose to mount your motors with zip-ties, I suggest tightened them in "Knots" (opposite directions).
After you tightened all mountings it's time to add some strength to our motors. First we will add some epoxy to bottom of motors for fixing wires (more details on David's Tricopter 2.5 build thread). Try not to put too much epoxy on it else you will have some troubles getting your motor in its mounting.
Then I decided to cut axles on my DT750. First I wrapped my motor in PVC foil because I was worried about small particles flying into motor. Then I cut it on half (20mm) with my Dremel tool.
Installation of landing gear:
As battery will be placed on the bottom of our quad we need landing gear to prevent landing on battery. I really liked topic about making Indestructible PVC landing gear, so I decided to use that topic for template.
First cut 4 10mm wide pieces of PVC tube. At first I used tube with 50mm diameter, but now I recommend using bigger tube because battery was too low and hit floor in a rough landings.
Then sand edges a bit and fix your pieces of tubing on your quad with 2mm zip-ties.
Well your landing gear is ready to use now.
Now it's time to solder 46 solder joints or 33 connectors if we want connectors on motor-ESC, ESC-extension, 4 extension cables into 1 extension cable, extension cable-battery. I know that there are possibilities for connectors to come out, but we'll risk that. I like connectors on everything, because you can simply unplug electronics and replace them. If you don't know how to solder yet you should see articles about soldering battery connectors and soldering thick gauge wire. I suggest that your soldering iron is heated at about 350°C.
If you don't like this step, you can skip it and just solder all wires together and put some heat shrink tube over them to prevent short circuit. The only connector you really need is battery connector.
Making Power breakout cable:
This step is only necessary if you haven't ordered power breakout cable or you want to solder your own.
First cut 5 10cm long pieces of 20AWG or similar wire. Then put 4 pieces on one side and 1 piece on other side and wrap it with a thick copper wire (I got mine by pulling one wire out of cable).
Now press a soldering iron on cables and wait for about 10 seconds to heat up cables. Then add solder until you think it's filled.
Now repeat same steps and make another breakout cable
It's time to put some heat shrink over solder joint and solder connectors on it. I'm using multiplex connectors from HK.
Installation of Flight Controller:
For flight controller I suggest using KK2 board from Hobby King as it is perfect for a beginner because you don't need computer to program it, it's even more stable as old boards and got lots of useful settings. It comes in a foam box which we will use to mount our board on a quad. As I want everything swappable I decided to mount KK2 board with Velcro tape. It absorbs some of the vibrations and let us change its position (for example: from Cross to Plus configuration).
Making a battery strap:
When I was ordering from HK I also forgot to order battery strap so I made my own from Velcro tape that I got from DIY store.
Well as tape wasn't self-adhesive I decided to hot-glue it on frame.
Programming ESC's:
In this step you should take your ESC's connect them into programming card (BEC plug) and connect battery. Then turn the brake off, select Ni-XX type (that ESC's don't switch off motors in mid-air) and set low voltage cut off.
Balancing props:
This is an important step to get your quad stable. You need a prop balancer some tape and of course props. As there is already article about ways to balance props I guess that I don't have to show you how to do it.
Connecting everything together:
Now get your motors into the mountings and connect them to ESC's.
Then put a zip-tie around wires to fix ESC's in place
Later connect your receiver with KK2 board as seen on the picture
Now connect one of the ESC's in M1 plug. This plug powers up flight controller and receiver. Then keep pressing the Down button until you get to the Select configuration menu. Select X-Quad configuration. Then go to show configuration and connect ESC's where they should be.
Turn on the receiver and test if motors are spinning in right direction. If they aren't switch two wires on motor.
Now it's time to put your props on, fix your battery and test it.
Some photos with new camera ;)
And finaly first flight!
And after more than fifty flights... finaly a broken prop!
After lots of flights (and crashes) I have to say I'm pretty impressed with quad-copters. They're so stable and durable. Here is a table of downsides and good sides of my simple quad:
Advantages:
- Durability (wooden frame, shortened axle)
- Cheap electronics
- Cheap light and durable frame
- Weight (pretty light)
- Absorbs some of vibrations (wooden frame)
Disadvantages:
- lots of twisting on arms (I recommend using thicker sticks for frame)
- Battery is on the bottom (possibility to damage it)
- Weight (could be lighter from carbon fiber)
- Not suitable for carrying a camera (Board and receiver on top, battery on bottom)
- If you bend an axle on DT750 it's hard to find replacement
To get a even smoother run, tru to balance the motors too...
You would get surprised how much this actual helps performance.
Nice simple build. Good job. But please, take some sandpaper to those landing leg rings for goodness sakes. ;-)
Keep up the good work
