Prop storage
by Lubis | October 7, 2012 | (7) Posted in Tips
If you, like me, have a lot of props in different dimensions laying around and want to store them in an easy way, you can make one of these from plywood or whatever you have at home. These measurements are for 10x47 and 11x47 props so if you use, say 12x4,5 you might want to increase the length (31 cm) a bit.
Mine is made out of 5 mm and 3 mm plywood. The frame is 5 mm thick and the dividers are 3 mm.
Here is the drawing for Google SketchUp: PropCabin.skp
Jake3dpilot on August 2, 2016
Nice build
Prop storage
