The Tri-Quadcopter I designed 3D printed at my school. I still need to order all the components and I am trying to determin what flight controller to use. I like to call it the mini Do-copter because its not a Tri but a quad in a Tri-copter like configuration. It doesn't Tri, it just "Does".
This guy has done it http://youtu.be/_wrCEvWXME8
Your best bet is probably this guy from DIYdrones
http://vimeo.com/41811715
He is using arducopter stuff, so I hope you have some programming buddies...Here is the thread, although I'm sure you've seen these already being as far as you are this project.
http://diydrones.com/profiles/blogs/ducted-fan-quadcopter
Good luck
How much programming knowledge do you have? You might have to customize a control board like the Multi-Wii boards. They are open source code using the Arduino stack, but you need to have a good foundation in programming.
Thats where I would start. But then again, I'm a software developer by trade.
You have one motor in the middle and three on the outside? Looks like it needs really small props, or four ducted fans. Roll and pitch would work as a normal tricopter with the centre motor just assisting with the yaw.
Counter to popular belief the flight controller can be mounted offset from the centre of gravity. Id suggest buying single battery cells so you can distribute the battery weight.
If you could tweak the design and send me one, I'll happily work out the software and electrics.
Lazyzero or pug398 or kapteinkuk or Minsoo Kim at RCGROUPS.
All four know the kk boards like the back of their hands. They could probably take the rear motor and servo segments from Minsoo Kim's V2.9 XXcontrol Y copter hex file and replicate another two with "relatively little" work. The central motor appears it would be a no-brainer reacting to merely throttle. You can find them moving around in the Multirotor category.
