Park450 Maintenance
by colorex | August 19, 2012 | (18) Posted in Tips
Here’s a quick guide on how to disassemble and clean a Turnigy Park450 brushless motor. This is a very well made and very strong motor for your RC plane. If you want this motor you can buy it here from HobbyKing:
Turnigy Park450 Brushless Outrunner 890kv
Turnigy Park450 Brushless Outrunner 1050kv
Turnigy Park450 Brushless Outrunner 1200kv
What You'll Need
 - Small Philips Screwdriver
- 2mm (I think) Allen Key
- Soft Brush
 - Soft Cloth
 - Rubbing Alcohol
Disassembling the Motor Remove the motor from the airplane. I had this motor on a FunBat, but I didn’t have any wheels on it, so I landed on the beach where I was flying and got some sand in my motor. The motor made a grinding/crunching sound when turned by hand.
Remove the four screws on the mount.
Using an allen key, loosen the two grub screws that hold the lock in place.
Grip the base firmly, and pull off the bell of the motor.
Cleaning the Motor
There is the sand - clean it off with a soft cloth or a brush. Use alcohol if you need something liquid to aid cleaning.
Notice the remaining spots, I think they are rust, and they will be hard to remove.
Add some oil to the bearings, to lubricate them and to prevent further rusting. Do the same with the bearing on the underside of the motor.
Reassembling the Motor
Carefully slip the bell back on, the magnets should pull it in place. Just be careful so you don’t knock out the bottom bearing.
Put the lock back on the axle, but make sure the little dent in the axle is perpendicular to the grub screw in the lock - otherwise you’ll get a dodgy fit. Press in the lock as far as it’ll go.
Tighten the grub screws back in place. You might want to use blue threadlock for more safety.
Reinstall the mount. If the holes don’t line up, rotate the mount by 90º.
Reinstall the motor in the aircraft, making sure you do it well. Reattach the spinner with the propeller.
Done!
Author:
André Elb aka ColoreX
Doctor3 on September 27, 2012
I must admit when i saw this posted i was like "pshh , ill never need to do this". but just got a grinding noise from my motor and has worked a treat - thumbs up
colorex on September 27, 2012
Thanks! Glad to be helpful :)
flitetest_argentina on August 20, 2012
finally an article from you!
colorex on August 20, 2012
Yes! I'm getting to it!
jetpackninja on September 15, 2012
Nice- I love articles with pictures!
When oiling the bearings use a light machine oil.
Some LHS carry a bearing specific oil that has a long needle for an applicator. Makes getting the oil into the right places easy.
I've seen the same applicators sometimes on sewing machine oil- would work great for this application too.
colorex on September 15, 2012
I fully share your point of view - I get tired of just watching more and more videos. With photos I can go at my own pace :)
And when you live in Ecuador and don't have a regular job, you have to stick with what your mom has. :D
rickehrle on August 30, 2012
Nice! I have one at my home made balsa (supposed to be)glider. I really like this motor. I tried some before and with this one I had the largest battery life. It is really quiet and has a lot of power. Can fly almost half hour with a 1300 3S LiPo and 8/4 prop. And the plane weights almost 800g and has 1.6m wingspann.
colorex on August 30, 2012
Wow, I have an 8x4 (TGY Sport) on it but it doesn't seem to give me that much as a 10x4.7 - which overheats it a bit. I used mine on an obese FunBat - Park450 + 25A RedBrick + 1300mAh 3S - but I used a 10x4.7 cut down to 9 inches diameter.
I want to build either a Diablo 3D foamie with it or a scratchbuilt 1000mm balsa Extra 300S.
By the way, I was talking about the 1050kv version. I used a 20A ESC and it handles quiet well, no overheat.
Yup, that's the same one I have - you can see that in the pictures. The heating I get is on the motor, when pulling a big prop.
oXton on March 25, 2015
Is this DC or AC motor? I applied 11.1 V from battery on 1050KV and it not rotates...some smoke went from the motor :/
Park450 Maintenance
