Parallel LiPo connector - Fast Tip
by Lubis | December 30, 2012 | (11) Posted in Tips
This is just a simple way to solder 3 XT60-conntectors together.
To make the two male-connectors, which connect to the batteries, hold together while soldering just tape them together.
 The back part of the connector makes a fine gap for the female connector to wedge in.
tophe75 on February 10, 2013
Simple, yet effective.
panther3001 on July 19, 2013
I'm adding this as a related article to my parallel charging article here on Flitetest.
True. Very simple, yet functional. Thanks for the quick tip!
jimmbbo on June 21, 2014
Clever rig, but am concerned about the small amount of contact area with high current draws... Have you done any testing of this unit to see if it has "issues" at 70 - 80 Amps?
Lubis on June 22, 2014
I've not tested that kind of amperage, but if you place a small piece of wire between all three poles when you solder it shouldn't be a problem.
Fearless FPV on January 1, 2016
This is fantastic! Thanks for sharing!
