Recently, my father-in-law crashed his slow stick. I wanted something he could build, grow into, and move up with. So I decided to build the nutball, Josh Bixler style, so here it is.
We didn't have a compiled list of measurements to go off of with Josh's plan, so I printed it out, did some math, and I think I got close. Now keep in mind that these measurements are just approximations, so you can be a little liberal on the exact dimensions.
I wanted to use the Scotch Extreme packing tape that Josh so often talks about, and finally found it in my town at Staples. Just as a piece of info for ya.
I have yet to fly it, so as soon as I do, I will update. The rudder shown in the picture is about an inch short of what it was supposed to be, so I will be redoing that as well. Otherwise, it looks good and should be a fun one.
The wings I would like to interchange on this one is a 3D wing, a sport trainer wing, and possibly a pusher jet (turning th prop around and swapping the motor wires). We will see what I come up with on it.
Update: 6/11/12
Added electronics, landing gear, and extended the rudder. Still needs push rods, a tail skid, and some color.
HK $0.99 landing struts, and 5 spoke 60mm wheels.
A piece of light plywood and six screws and its good to go. I hot glued the plywood down, drilled the holes and screwed it all together with self tapping screws.
The gear sweeps forward a bit more than I thought it would. I'm thinking I could have mounted the gear further back. With a 450 mah 2s in the nose of the plane, it balances perfectly on a 5 inch cg. I may have to put my 950 up front to get it to balance as needed. I'll update it once I've flown it.
They are on page 3 post #26 of this thread.
http://forum.flitetest.com/showthread.php?1681-NutBall-Scratch-Build/page3&highlight=nutball
PS Love the landing gear.
Flew it twice yesterday, what a fun little plane to fly. You can keep it just a few inches off the ground and just walk it around the feild. Love it!
