Maintenance of helicopters: Tail
by wongthomas | August 7, 2012 | (0) Posted in Tips
Let's get to it.
The maintenance of a helicopter, is something you need to do every now and then. I do it after 40 flight, after a crash or once a year. whatever comes first.
If you have other items you check plz let me know so I can update my checklist
Also I keep a log of parts i change, so I can have the most common ones in stock.
Checklist of a pro type helicopter:
  • Is the tail boom bent
  • Is the stabilizer fins cracked
  • Is the any of the gears striped
  • Is the torque tube bent or cracked
  • is the pushrod bent
  • is the tail shaft bent ?
  • is the tail blade holders cracked
  • Is any bearings damaged
When I have it apart I always clean and relube all the bearings.
ABQ Bobcat on September 10, 2012
Nederlander?
