How To Make Homemade RC Hinges
by the world without servo's | May 9, 2012 | (0) Posted in Tips
Callum. W
Instructions
1.   Iron-on Hinges
Cut several strips of iron-on covering about 1/2 inch wide and 1 inch long. It is best to use the same colour for the hinge as you will use on the entire part.
Turn the strips so the surfaces with the glue face each other. Position the strips so that they overlap by a half inch. Use an iron to bond the strips together. There will be a glue side facing up and one facing down.
Place the strip between the movable and stationary parts. The first strip will be over the stationary part and under the movable part. The next strip needs to be opposite, over the movable part and under the stationary.
Iron the strips in place to complete the installation. These hinges work best on elevators and rudders.
2.   Floppy Disk Hinges
Cut open the sleeve of the floppy disk and remove the magnetic media inside.
Cut the media into strips that are 1 inch long and 1/2 inch wide. These strips will become the hinges.
Use a light sandpaper to scuff up the hinge material on both sides; this will help the glue adhere.
Cut slots in the stationary and movable surfaces with a sharp hobby knife. Take care and make sure the slots line up on the two surfaces. Use epoxy to secure these hinges in place.
3.   Tape Hinges
Bevel the lower edge of the movable surface that needs hinging. Make the bevel a 45 degree angle. Use a sharp hobby knife or coarse sandpaper to create the bevel.
Align the stationary and movable surfaces so that the movable piece is at full deflection downward. Apply a strip of clear packing tape along the top edge so that the tape touches the movable and stationary pieces equally.
Position the movable surface so that it is fully deflected up. Apply a second strip of tape along the edge so that both surfaces are equally covered by the tape.
Tips & Warnings
·        Only use tape hinges on electric "foamy" aircraft; the oils from nitro fuel will cause the tape to loose its stickiness.
·        When using floppy disk hinges, you can use the sleeves for hinging material on larger planes.
munzli on May 9, 2012
great idean with the floppy hinge... and you guys forgot the hot glue hinge as seen here for example: http://youtu.be/N4Of1IjTIIo
the world without servo's on July 24, 2012
thanks will add one now
AERODROME on January 6, 2015
another good material is the top of cascade auto dish soap container it is a natural hinge after cutting the strips i use a hole punch to make the glue tstick better
