HobbyKing HK401B gyro
by wongthomas | May 13, 2012 | (5) Posted in Reviews
A review of the HK401B gyro from hobbyking.
Rating (1-10): 1
Pros:
    - Cheap
    - Simple
Cons:
    - Does not work as a tail gyro on a helicopter
I will look into the use on a plane, as i seen that others have more luck useing it that way, but as a tail gyro on a helicopter nope.
Link to product: http://www.hobbyking.com/hobbyking/store/__10113__Hobby_King_401B_AVCS_Digital_Head_Lock_Gyro_.html
wongthomas on May 13, 2012
any suggestions are welcome on things like other products to review or just something else to like me to talk about ;)
lukeer31 on May 13, 2012
The gyro isnt too sensitive on a heli. BUT you need to plug the extra signal lead into CH5 on your receiver and set the GAIN via your transmitter manually, when you do this it is a relatively good gyro :) (but no where near the best)
Hey lukee31, I do know that you need to set the gain on the transmitter, Im happy that yours work fine, as I tried a lot of combo's. and the wag only stop with gain about 7% (spektrum), and there the tail is loose.
check out this video. http://www.youtube.com/watch?v=sDRD9ftAEfQ
and the one that works, is the old stock, but the other 8 I got is the new stock.
But if you got the new stock and it works, Im happy to hear that
