H-Quad all electronics inside
by TheBeroys | October 9, 2012 | (5) Posted in Projects
Hi,
I wanted to make a H-Quad that hold all the electronics including battery inside the fuselage.
The frame is made out off wood 15x15mm bars.
It has place for 2x3 cell 2200 mah batteries, when flying without camera for balance.
When filming I just use on battery to counter weight to the camera.
To access the battery and electronics. I just bend the cover, made of flexible plastic. Mounted with screws in the outer end, and Velcro in center.
 See pictures below. And also a movie off the first flight with camera on a windy day above.
Top View.
Open back compartment.
Open Front compartment.
Chris101 on November 5, 2012
This is what I am looking to do, but just with on a larger size.
Really awsome idea!
TheBeroys on November 5, 2012
Hi, Thanks.
Which size are you planing to build? My size approx like the original that flight test was building.
Chris101 on November 30, 2012
Im looking to build a 750mm size. But also, im looking to get 30mins of flight time minimum. Would you know how I can go about doing that?
Also take into consideration I will be fitting a GoPro hero 2 onto the craft.
zev on February 25, 2013
30 mins of flight time as darn near impossible. the number one way to get flight time is save weight, so an enclosed quad doesn't really make sense. the other think is super efficient motors and props, and a HUGE battery.
the current world record quadcopter flight (65mins, I think. and that was with out a camera. I am sure a goPro would cut that time in half) had 35$ motors, 50$ props, and two 11000mah battrys, 260$ each. yikes!
Jake Wells on October 14, 2012
That's a very cool little guy.
TheBeroys on October 15, 2012
Thank's. The design works good I think.
flyboy_____ on June 19, 2013
I LOVE the H Quad so I made one EVO3 with boxed frame and retracts look here:
http://www.youtube.com/watch?v=Mq3vRr7Cm6c
