After flight testing myF22 Parkjet I decided to try and see if a modification from pusher to tractor would improve the performance numbers of the battery flight time. To my surprise, a 25% increase in motor run times was seen. I went from an 8 minute flight to a 10 minute flight time.
I do not want to spoil the fun, but you are using a different prop in this tractor setup. This might actually be the main reason for this performance increase you observe. Some props are more efficient then the others, even with the same parameters... I'll just mention EMS and APC...
What do you think?
I wish I had an explanation for this, but at this point, I am glad I made the modification from pusher to tractor.
I will try this out during my next build...
Glad you got it working better!
