E-Flite Edge 540qq
by flitetest_argentina | January 23, 2013 | (22) Posted in Reviews
E-Flite Edge 540qq - REVIEW
In this episode of FliteTest Argentina, we had the possibillity of review the new airplane that is the e-flite edge 540qq by Horizon Hobby! Enjoy the episode and wait for more review like the durafly trojan and the P-26 Peashooter by HobbyKing...(they are arriving in 1 month)...
Key Features
  • Hollow-molded foam construction with carbon fiber reinforcement
  • High-speed digital servos and Spektrum™ Nanolite receiver installed
  • High-power BL280, 1800Kv outrunner power system installed
  • High-performance custom propeller and matching spinner
  • Two-piece removable wing with carbon fiber joiner
  • Magnetic battery hatch provides instant access
Specs
Airfoil Shape:Symmetrical
CG (Center of Gravity):1.57-1.65 in (40-42mm) back from the leading edge at wing root
Control Throw (Ailerons):Low: 15mm up/down, 30% expo; High: 25mm up/down, 40% expo
Control Throw (Elevator):Low: 8mm up/down, 20% expo; High: 35mm up/down, 60% expo
Control Throw (Rudder):Low: 13mm right/left, 20% expo; High: 20mm right/left, 35% expo
Experience Level:Intermediate
Flying Weight:8.3 oz (235 g)
Fuel Type:Electric
Is Assembly Required:Yes
Main Wing Tube Length:340mm
Main Wing Tube OD:8mm
Motor Size:Park 280 (installed)
Overall Length:24.1 in (612mm)
Plane Type:Scale Civilian
Power Plant Size:180-280 Electric
Prop Size:6.8 x 3
Radio:4 channels minimum
Recommended Environment:Indoor/Outdoor
Recommended Motor Battery:3S 11.1V 450mAh 30C Li-Po (required)
Servos:Four 3.5-gram digital servos (installed)
Speed Control:10-Amp brushless (installed)
Spinner Size:1.5 in (38mm)
Trim Scheme Colors:Green, purple, silver
Wing Area:162 sq. in. (10.4 sq. dm.)
Wing Loading:7.7 oz/sq. ft.
Wingspan:26.0 in (660mm)
No Comments Yet
Be the first to leave one!
E-Flite Edge 540qq
