DIY Vibration Dampers
by jamiedco | June 14, 2012 | (21) Posted in Projects
hello guys . this is a vid on how to make vibration dampeners for your tri or quad copter .
they are quite simple to make and give a really good mounting .
DONT FORGET TO RATE !!!!!!
colorex on June 15, 2012
Great! Five Star! But I have other plans :P
L33n0x on June 15, 2012
Thanks Jamie !
I need to try with my Arducopter !
ABQ Bobcat on September 16, 2012
Quite the liberal use of G n R! LOL!
Great tip, I'll be using it on the i86 board that my students are building a quad with. Thanks for the help.
Clear Prop Productions on June 16, 2012
Great Idea Thanks For Sharing!
Brainanator on June 25, 2012
Look very good!
UndCon on July 16, 2012
Nice tip.
To secure the 2 nuts you actually tighten against each other.
They will eventually come loose. You are most likely better off using blue loctite that can be removed by hand tools if needed.
//UndCon
apache64 on July 9, 2012
Sorry i cant view this in Germany, the music is forbidden :-(
