Hi,
About aweek ago I crashed my Bixler hard to the ground what lead to a cracked open nose and a broken vertical stabilizer. The crash starts at 4:30
The vertical stabilizer was not a problem I glued that back on with hot glue but the nose was `transformed´ into a shape which I could not glue back directly because the sides did not fit and both the sides where facing to the outside.
I solved this problem by putting the nose into boiling water this allows you to form the epo foam to straight lines again. (you could also form it round if you press it to an round surface but that was not what I needed.)
Now I could glue it back together for this part I didn't use hot glue but construction glue look at the picture
After one night the glue was dry and now my plane looks like this
this is the first flight after the crash
I hope you learned something from this.
Job
