This video will run you through the process of updating the firmware of your 9xr Radio including uploading your Model Data etc. I've also included part of a previous video that will run you though the tricky process of install the AVR Programmer Drivers
This is the Programmer to purchase since it comes with both 10pin and 6pin connectors
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=21321&aff=460671
I got mine from ebay only because I was in a hurry to do the firmware update on my 9x, however it came with a 10pin connector only. I ended up having to make an adaptor to make it work with the 9XR Radio.
In any case I hope this is of help!!
