51" AJ Slick ARF Review
by VoroRC | April 19, 2013 | (6) Posted in Reviews
51" AJ Slick From 3d Hobby Shop. This is a gorgeous model and flies amazing! Remember to rate this article, and comment with any questions you might have I'm very approachable and always open to any comments or questions you might have. For more reviews or flight training videos check out my youtube channel.
VoroRC's Youtube
This plane has plenty of throw on all surfaces. Recommended throw for 3d flight. Ail (45 Degrees) Elevator (50 Degrees) and Rudder ( as much as possible without touching the elevator)
Servo Saftey clips are a huge part of any model.
Remember to always use Thin CA to glue all joints to any model.
When Zip tying any ESC, zip tie the wires. Not the ESC it self.
Use masking tape to prevent wear on the wood from hod wires.
Two battery straps is always better than one. Always use Velcro, it's your best friend in this hobby for keeping thing secure.
Hard wear and power specs.
Hacker A30-10XL Version II
Castle ICE LITE 75amp.
Hitec HS-85MGs all around the air frame work great!
Recommended battery is 4s 2600mAh - 3300mAh 40C-65C
Receiver I'm using is Spektrum AR7000, but you can use just about any full range receiver. I've even used an AR400 for awhile and it worked great!
Prop I recommend is the Xoar 14/7. But, APC 14/7 also works.
Feel free to ask questions, I'm always open to anything!
mattplaneflyer on April 19, 2013
Great review! This will be a great plane to upgrade to from the 40" epp edge that I own from 3dhobbyshop.
Tryingto3D on March 4, 2021
Whats is your recommendation for CG? The manual measurements are from wing tips?
