5$ DIY Ultra simple FPV Pan for Micro Camera
by val0production | August 27, 2014 | (17) Posted in How To
Hi it's Val.
Check my video podcast !
Val.
kkuenzel on August 28, 2014
What video camera are you using?
val0production on August 29, 2014
Fatshark 600tvl cmos
seansgrandad on August 29, 2014
The simple solutions are often the best.
Can I suggest maybe using the "4 arm" servo arm to give a bit more security.
I will use you idea with my Mobius mounted on a ply plate.
anonymous rc pilot on August 27, 2014
I like it simple cheap and to the point. ill have to put one of these on my next plane.
danallen82 on August 29, 2014
That is possibly the single best use of the rudder channel on a rudderless fixed wing! Maybe it is even worth trying on a ruddered plane.
apnewton on August 27, 2014
Excellent, very minimal
ashtodust2000 on August 27, 2014
Great job, super simple and light weight.
c.sitas on August 27, 2014
You could also compound that servo . Could go all directions now. A great cheap idea.
Raycycle on September 10, 2014
I mounted my Fat Shark Pilot HD 720p - HD FPV Camera on to the canopy of my RADIAN glider. I used two Go Pro mounting brackets, One bracket bolted to the canopy and the second attached to the first upside down and the camera attached to the adhesive side of the bracket. The transmitter and antenna are held on behind with velcro. Here is my email if you would like a photo. ray300downtown@gmail.com
