30-68 Eurofighter Typhoon hot wire cut EDF 70 mm
by aangeles123 | November 22, 2017 | (3) Posted in Projects
I apologize for my English This is my first project without plans...well I made the plans.
I hotwire cut a Viggen (thanks to David). I learned so much with it, but I like the Typhoon more (sorry David). I started using SketchUp, finding a good typhoon model and scale to fit my 70mm EDF. The original EDF comes from my Viggen as it was already dead. It lost a rudder on a fast roll and hit the ground nose down
My goals are:
1.- To make it fly
2.- To make it a good looking jet
3.- To have retractable landing gear (air inlet is on the bottom so maybe there will be no belly landing)
4.- To have airfoil wings
Specs:
Eurofighter Typhoon EDF Luftwaffe
Material Foamular 2" inch (pink foam)
Wing span 800 mm (31.5 inches)
Length 1130 mm (44.5 inches)
flying weight: ? (hopefully 1200 gr)
Landing gear: tricycle retractable max 2kg AUW
Edf: Detrumm 70mm EDF
Esc: 60 A
Battery: 3000 mAh 14.8v 30C Lipo
First, I measured all the electronics, battery, EDF, ESC's, servos..download SketchUp models of everything to scale.
I did some research about EDF's and make sure those findings, things like FSA  (Fan sweep area), are meeting in the model. Next, I choose the place where it should be a section of the template.
Then it was exported to a CAD file and printed.
Here in Mexico, it's not easy to find wood cutting for the template but there is a paper and works great. It is not easy to cut and I use a cutter has to do a 2-3 pass to cut, can be sanded best of all you do not need any wood and the hot wire goes easy.
Hopefully, I will maiden it soon.
Steveacer on January 18, 2019
Incredible, looks fantastic!
grifflyer on November 22, 2017
oooohhh that looks great!
are you going to paint it?
aangeles123 on November 22, 2017
yes, i love Eurofighter Typhoon S 30+68 Luftwaffe (60 Jahre Luftwaffe Special Paint Scheme)
i has done some paint testin to match ...https://www.jetphotos.com/registration/30-68
JamesWhomsley on November 22, 2017
Wow, cool build!
Raccoonworks on November 23, 2017
Impressive! I plan on building a hot wire cut F-80 here over the winter.
aangeles123 on November 24, 2017
i plan next to do a Dri Fokker,then a su-27 pusher, and then a 70mm edf Mig 15 all of them hotwire cut
