Introduction
I decided to jump into on the 180mm trend. Why not? It's not like I have enough multirotors, (he who has the most wins). Anyway after some research I decide to go with the ShenDrone Tweaker.
Why am I doing this? I wanted to find out the following, and hopfully be able to pass what I learn to others to help with their puchasing decisions. I wanted to find out :
- Why are the 180mm class of mini quads suddenly so popular ?
- What are they like to build ?
- Any majour gotchas ?
To date I have done three rebuilds of this wee 180. But before we get into the nitty gritty here's a teaser video of the 180 build on its first LOS shakedown flight.
The nitty gritty
Full Build here : http://www.bluefish.net.nz/2015/09/4s-capable-shendrone-tweaker-180.html
Current Build parts list:
Dual regulator 5v/12v 35 PDB
LittleBee 20amp ESCs (blHeli 14 / Damping light/Motor timing med/high)
D4RII - Stripped down
Naze32 Acro
DYS1306 / 3100kv DYS1806s / 2400kv
A shout out to GearBest.com for supplying DYS1306 /3100kv motors for this build. The DYS1306 are very popular at the moment due to the trend with the smaller 180s and sometimes hard to get. GearBest sent them out quickly and they are starting to get a wide range of multirotor parts.
I also made a number of 3D Printable parts for my ShenDrone. The 3D files are on thingiverse
http://www.thingiverse.com/thing:984695
This build was to allow future expanstion to larger motors and 4S. So the PDB and the ESCs are 4s capiable.
All the FPV gear is mounted onto the bottom of the top plate to allow easy removal for maintance. This is differnet to my first build as I move the video TX forward. This allows for camera mountiung on the front and the use of the battery to get the correct COG. My eariler build (below) had the TX antenna at the rear. This limited the ability to move the battery far enough back. This also made for a tidy wiring.
All up weight is 260-270 grams
Custom & cheap arm protectors using TPU 4mmOD tubing. As you can see from the video I fly over tarmac so wanted cheap frame protection. The 3D printed protectors work well but dont last to long. I am hoping this solution will last longer. Also alot cheaper and faster to replace.
Finally got all the wires tidily hidden away.
Build One :
Build one was to get it into the air as fast as I could as I was waiting on parts. But is still a good way to have a minimum tidy build.
Full build here : http://www.bluefish.net.nz/2015/08/shendrone-tweaker-180-build.html
This used a
4-1ESC 12amp ESC
Naze32
DYS1806 2400 motors
D4RII
HQ4045s Props
I made some custom plate seperators for the ESC and the Naze & a camera mount. The 4-1 makes fora tidy build.
I mounted all the FPV gear on the bottom of the top plate to make it easy remove for maintance.
Rear 3D printed bumper for LED strip and XT60.
Final build.
Conclusion
Overall the 180 sized frames are just plain awesome fun. Its like that first experience you had when you went from a 450 down to a 250 class. Its small, more nimble and just feels like more fun. They sure can fit into small places when doing proxcimity flying. So that answers my first question
- Why are the 180mm class of mini quads suddenly so popular ? : Huge Fun !!
- What are they like to build ? : Tricky... not much room to fit everything.
- Any major gotchas ? : Planning, fitting everything in, Motor/prop combos.
Overall 180 are just a heap of fun !!
I hope that a 1306/1806 - 3100kv motor is released with a 3mm shaft, that would be perfect for the 180-150mm class miniquads.
