170mm Super Simple Micro H-Quad
by apolak | May 12, 2015 | (0) Posted in Projects
 The SSHQuad Micro has all of the same simple and effective features as the larger 250mm SSHQuad PRO, but in an even smaller 170mm micro format. The SSHQuad Micro is designed to accommodate 4” props with many standard components, such as 1306 motors, 30mm flight controllers and 6/12A ESCs. Configured as recommended, a 6:1 thrust to weight ratio can be achieved with a total mass of 165 grams.
Recommended Bill of Materials:
[Qty. 1] SSHQuad 170mm Micro Frame
[Qty. 2] DYS BX1306-3100KV (pair)
[Qty. 1] 12A HV 4in1 ESC (w/ DuPont Cable)
[Qty. 1] Naze 32 Acro (no pins)
[Qty. 1] FrSky D4R-II
[Qty. 1] 450mAh 3S 65~130C NanoTech LiPo
[Qty. 2] APC 4141E Propeller
[Qty. 2] APC 4141EP Propeller
[Qty. 1] M5 Low-profile CW Prop Nut (4)
[Qty. 1] M5 Low-profile CCW Prop Nut (4)
[Qty. 1] M2x8mm Bolt (20)
[Qty. 1] M3 8mm Nylon Spacer (10)
[Qty. 1] M3x20mm Nylon Screw (10)
[Qty. 1] M3 Nylon Nut (10)
Assembly:
The top side of the SSHQuad Mini frame is a flat mounting surface with a high gloss finish. Beneath the frame are four channels for routing wires, mounting landing gear or embedding LEDs. Prior to assembly, a reamer or hobby knife should be used to clear out each mounting hole and ensuring a nearly flat mounting surface for the motors.
IMG_8578 IMG_8575 IMG_8581
Carefully bend the motor wires near the base of the motor and insert the cables through the routing slot at the end of each arm. Using four M2x8mm bolts per motor, secure the motors to each arm and route the wires beneath the arm to the center of the frame. Each motor wire should be cut to approximately 9cm in length to reach the 4in1 ESC. Cut a strip of Velcro and route it through the battery strap slots at the center of the frame.
IMG_8601 IMG_8611 IMG_8618 IMG_8634
Solder a cable with battery connector to the solder pads on the bottom of the 4in1 ESC opposite the signal wires. Solder each of the motor wires to the top side of the ESC, crossing the appropriate wires to ensure proper rotation of the motor. If the ESC will later be reprogrammed for reverse operation, the order of the wire connections does not matter. Ensure that ESC outputs label M03 and M02 are located at the front of the frame with the main power on the right side and signals wires to the left when viewed from above. Bolts or standoffs may be used to temporarily secure the ESC while soldering for proper alignment.
IMG_8645 IMG_8664
The 4in1 ESC must now be reprogrammed with BLHeli firmware if so desired. Connect the 4in1 ESC to a battery for power and the ground and M01 signal wire to a programmer, such as the Turnigy USB Linker. Leave the red 5V BESC wire disconnected from the programmer. Open the BLHeliSuite programming tool and select the Turnigy USB Linker as the programming device. Set the BAUD rate to 9600 and connect to the ESC. Flash the latest version of BLUESERIES 12A MULTI to the ESC. Once complete, reverse the rotation direction of the motor if necessary. Alter the following settings and repeat the process for each ESC by disconnecting the previous signal wire and connecting the next signal wire to the programmer.
4in1 ESC:
M03    M02
M04    M01
M01: standard rotation
M02: reverse rotation
M03: standard rotation
M04: reverse rotation
PWM Frequency/Damped: DAMPED LIGHT (Enable ONESHOT using Cleanflight Configurator)
Motor Timing: HIGH
Temp Protection: ON
Remove the protective cover from the FrSky D4R-II Receiver. The D4R-II should be updated at this point if so desired. After the update is complete, carefully cut each of the pins and remove the black plastic retainer holding the pins together. Desolder each pin an place a jumper between channels 3 & 4 to enable CPPM. Connect three 3cm wires for power, ground and channel 1 (CPPM) to the channel 1 port on the D4R-II. Solder the other end of these cables to the power, ground and CCPM (3) pads on the Naze 32.
IMG_8696 IMG_8699 IMG_8701 IMG_8718
Unplug the DuPont cable from the 4in1 ESC and cut the signal wires to approximately 5cm from the connector that plugs into the board. Solder these ends to the Naze 32. Be sure to switch motor wires 3 & 4 as follows.
4in1 ESC:                  Naze 32:
M03    M02      ==>    M04    M02
M04    M01                M03    M01
IMG_8703 IMG_8708
For FrSky telemetry, remove all but the TX wire from the FrSky provided telemetry cable and shorten the TX wire to approximately 3cm. Solder the TX wire to the telemetry pad on the Naze 32. Cut another 5cm wire from a scrap piece of wire and use it to connect to any pad on the 4in1 ESC shared with the positive battery lead. This wire is then connected to the positive battery pin on the Naze 32 for measurement of the battery voltage.
IMG_8734 IMG_8743 IMG_8747 IMG_8751
Place double-sided foam tape on the top and bottom of the D4R-II. Secure the D4R-II between the 4in1 ESC and the Naze 32. Bolt the Naze 32 and 4in1 ESC to the frame using the 8mm M3 nylon spacers, 20mm M3 nylon bolts and M3 nylon nuts. The M3 nuts are placed into the captive slots beneath the frame for ease of assembly and to prevent the nuts from coming loose. Before securing the roll bar to the top of the frame using two zip ties, update and program the flight controller with the Cleanflight user interface. Bolt on the props and you are ready to fly.
IMG_8766 IMG_8840
Bayboos on May 13, 2015
I'm not into the quads that much, but the article itself is great!
KiwiRCFlyer on May 13, 2015
This is a really clean build. Nice work. Let us know how the 4 in1 ESC goes.
danallen82 on May 13, 2015
I love how clean you build is. Minimal connectors are just sweet. Well done.
WOW! What a clean build, NICE!
AERODROME on May 13, 2015
YOU SHOULD COLLECT ALL THE PARTS AND SELL IT WITH A BUILD VIDEO ON CD
BirdMan9876 on May 16, 2015
This is an amazing build! you are such a great designer! I would also like to see a flight video!
-Thanks
