The Monster Jet. The name says it all. This is a great Monster Jet of a motor and should only be used by the experienced hobbist. This is a bit larger motor when compared to other park jet motors and in fact, lets call this a field jet motor. No park can handle this one :) To put this into terms most will understand, a 2-3 pound plane will go nearly 125mph when using this motor. If you do want to see this in action, just click here YouTube video.
Size does matter. The bigger the motor, the more powerful it typically is. The Monster Jet is about a 500 size brushless motor and turns a 2 bladed prop around 20,000 RPM.
A few different Options. Other than its extreme speed, another great feature of the Monster Jet is that it comes in two different styles, A 2200kv and a 2400kv.
 The 2400kv motor is for those who want to go VERY fast but stay with a 3S or 11.1v Lithium Battery Pack.  The 2200kv motor is for those who want to fly extremely fast,  this version will require a 14.8v (4S) Lipo pack to hit these extreme speeds.
I’m sure that made not much sense to most, so let me try to explain it better.
- 2200kv 11.1v battery 7 x 6 prop
- 2400kv 14.8v battery 7 x 5 prop
Hardware. Like all the Grayson Hobby motors, the Monster Jet comes complete with gold 4.0mm gold quick connects, (motor side already factory soldered ESC and shringk in accessory bag) prop collet, mounting screws, and a cross mount.
So if you are an experienced rc flyer who enjoys flying electric airplanes extremely fast airplanes, then check out the monster jet from Graysonhobby.com
