Water proofing your ESCs, your reciever, servos and other water sensitive parts is not near as comlicated as you might think. If you are flying in humid areas or even on snow for an example—taking a little bit of time to do some water proofing is time well spent.
These techniques for water proofing use a pretty small combination of products. The ones that Peter uses in this video are called Corrosion X, Corrosion X HD, various epoxies and TechSpray.
Corrosion X HD worked great with servos. You'll need to open up the housing and spray inside all of the components. When you're finished, be sure to clean the outside with isopropyl alcohol, otherwise the hot glue won't stick!
This is an extreme test that we are showing you (completely submerging our electronics) but we wanted to show you how effective these sprays can be at protecting your electronics from moisture.
In some situations, you can even spray your electronics after exposure to moisture.
These sprays can even work in salt water!
Epoxy is the best way to seal your ESC, hot glue will not work.
Thanks to everyone who submits articles and shares knowledge in our Forums. We learn great tips like these from viewers like you, so thank you for your feedback and interaction!
Here's Rustoleum - https://www.youtube.com/watch?v=DZrjXSsfxMQ
People use dielectric grease on car battery terminals too, to prevent that white corrosion from forming... but some also say you should only grease it AFTER the connection is made, because unlike a screw connection, car battery terminals aren't good at squishing grease out of the way when you tighten them down.
A bullet connector shouldn't have any problem. I know from experimentation and experience that screw connectors, as on light bulbs and flashlights have no trouble with an insulator (I use SuperLube synthetic grease, myself).
Can you use that spray on cameras? I'd like to use it on my Mobius.
Also, can it be used on barometers? Doesn't it damage the membrane?
if anyone else tryed it, please share the results, maybe we'll find a way to save our expensive toys :D
keep up the good work !!! what you are doing helps so many people in so many apects of this great hobby !!!!
Grant Williams
EDMONTON ,AB
CANADA
I am a 4 month old noobie with a RC Eye One Xtreme Quadcopter (being modified to carry a Phoenix Flight Gear Frame shortly). This has a Barometer for altitude hold. I don't use this attribute much (at all), but being a flier in the Massachusetts (SNOW) I would like to have a little more electronics protection.
Please note i started out like you suggest with a toy - then i was hooked the Xtreme is my second step. Got it because it looked like the barrier to entry to have a quacopter (i hate the word and connotation DRONE), where i can turn off the stabilization. I will be doing this as soon as i have a stronger stiffer air-frame.
I have yet to get the nerve up to purchase a Versa. I want to make sure that all the components work correctly together, including the radio and such as a starter. I know the information is all here, but it is in many different places.
It would be nice if you could have a parts list for beginners for a "RTF Versa" including your recommendations for a radio (Spectrum DX6i) and such but as a build. My other complaint is that there is no "One Stop Shopping" source to buy all the components in ONE CLICK. That would be great for a noobie like me. I am like Josh - I am cheap - but when i purchase something I want it to be correct the first time.
By the way I love your videos (I am an Ohio Boy myself), love the camaraderie and everything about you guys. Keep up the good work and God Bless.
Peter - i love your insights and the things you try - you are one crazy dude.
Next time I get back home I will look you up.
Mark Occhionero (aka Floyd the Owl)
Thanks for the tip, he said sarcastically.
So my question is do I need to reapply the corrosion X and if so how often?
-Thanks!
Kyle
