THE MICRO DRONE
by agvr35 | July 1, 2013 | (0) Posted in Projects
This is basically it, it's my first scratch built rc plane. I thought this design was pretty cool and wanted to share it with you guys and learn more about rc airplanes. I took alot of this design from many different planes that inspired me, I put this one together which includes alot of the other designs' features. It would be awesome if you guys can leave some comments and let me know what you think of it. This way I can learn from my mistakes and make my next planes so much better. http://www.youtube.com/watch?v=vby8TSznJbs
Thanks, Alex.
Bbjen on July 24, 2013
It looks tail heavy, I am currently making a similag one and the cg calculated from http://adamone.rchomepage.com/cg_calc.htm was about 80mm from wing chord. Which has me making a much longer nose than expected.
agvr35 on July 30, 2013
thank you very much! that is super cool! i might make a version 2!
Antheman54 on July 24, 2013
Nice job
thanks
rcspaceflight on July 24, 2013
I agree with Bbjen. I can't tell from the video if it is tail heavy or not. But the plane looks like it has too much of it's weight behind where the CG should be, and very little plane in front of that point. It won't look as nice, but the best solution is to extend the nose and put the battery as far forward as possible. Simply adding weight to the nose would make the plane heavier than it needs to be.
Otherwise it looks like a great plane. Keep building, designing, and experimenting.
thank you, i actually have a blog! i have already made many designs of planes and I may do a version two of this plane.
sailorJohn on July 24, 2013
This is what it's all about.
:D
THE MICRO DRONE
