taking foam to the next level
by brianm311 | June 24, 2014 | (22) Posted in Projects
with all i have learned from flite test and the rc community i decided to take my foam building to the next level,with no plans to go by and a few thoughts mulling around in my head i decided i would try and build something a little different staying in the medium of foam of course but different so i took some measurements from a plane i had (sensei) and i began to build, like i said there are no plans for this plane but i hope it will inspire others to do the same,a little foam some tape an some imagination an the sky's the limit! (no pun intended!) and of course the flitetest site there is some great tips and advice to guide you through the process, (materials, 3 sheets construction paper,one sheet foam board(just for the body i used 3 total 2 more for my wing) tape and a glue gun,
formers are 6in by 4 1/2 the tall one is 7in by 4 1/2
i used a yard stick for the body rib, after i ripped them on a table saw i could align the 2 giving me exact location markers for my formers
here you can see the coffee sticks in place for support and attachment of my construction paper
i used wider popsicle sticks i got at wal mart on the bottom
i used 1/4in ply on the bottom for my landing gear mount
starting to cover the hull in construction paper shiny side out
the top beams where the wing mounts are also strips from a yard stick
getting the rudder an elevator cut
body almost finshed
here you can see the rudder an elevator in place and where i stopped my formers
servos for rudder an elevator mismatched as you can see (hence the name recycler) i used parts from the parts drawer to build this the only thing i had to order was my motor
landing gear is now on
i made my cowling from an old fan that had died just needed to cut out for the motor
battery box in place i made this out of 1/4 ply as well
oops didn't do something right here battery is a little tall in it's box oh well i think i can make it work!
adjustable mount in place, makes it easy to adjust for thrust angle i'm useing a grand turbo 2820 with a 11.6 prop an a 11.1v 2200 mah with a 45amp turnigy speed controler
for the wing i did a ten inch bottom  flite test style wing i added a 1/4 inch dowel on top of the foam spar for strengthman i can't wait to fly this!
here it is finished havn't flown it since the maiden bad weather ( soon though! )
wing is 58in and the body measures 481/2 for the graphics i used a red an black sharpie on the wing an on the body i used red tail light repair tape from wal-mart over the wing i put a layer of clear to protect the wing
paulnb57 on July 23, 2014
Nice work!
brianm311 on July 23, 2014
thank you!
Rc Mania Cyprus on July 23, 2014
Beatiful mate!
thank you!
sailorJohn on July 23, 2014
Awesome!
thank you!
Willsonman on July 23, 2014
Its fantastic that so many more people are discovering what can be done with foam and traditional building methods. Great job! As a shameless plug...
http://forum.flitetest.com/showthread.php?8476-1-6-SE5a-Building-scale-with-DTFB
More folks should try this as it is a rewarding building experience.
that is a beautiful plane!! well done!! and i totally agree it is a rewarding experience the joy one can experience is beyond any you will ever get buying a pre- built plane! thanx!!
ifly2 on July 23, 2014
nice thing , hows it fly?
it's been one of my new fav's in my hangar flies as wel as it looks thanx!
shermanhartman on July 23, 2014
That cowl using the fan is perfect. Looks great.
thanx! i did't quite know what i was gonna do for the cowl and i as was sitting there brainstorming i looked over and "bing" the light came on!!! built another plane for a friend his has one as well!! they work great!!
scottie on July 23, 2014
nice work mate,like the idea of covering in paper. must make rough landings interesting tho :P
cheers
thanx! the paper actually worked out well iv'e flown it now 50 or more times since i submitted this article and it is still mint, even after folding the landing gear(small design flaw now fixed) it is also removable so it is easy to replace!! thanx again !!
Yogenh on July 23, 2014
I really love how great it came out. Looks so good hope that you keep up the good work
rahul.sutar on July 23, 2014
Awesome work dude !!!!! Never thought that foam can be used this way !!!!
Great work. !!!
brianm311 on July 24, 2014
thank you! opens up a whole new venture in foam plane building for me!!!
Kiowa Mech on July 25, 2014
That is awesome, great effort the paint job looks great.
brianm311 on July 26, 2014
thank you!!
Petrie on July 26, 2014
Good work. I'm new to foam. How were you able to do the compound curves on the windscreen?
thank you! i used construction paper so i was able to bend it to fit, it did take a few tries to get the right shape that allowed me to do the bend with the best results
#3 on July 26, 2014
wow to cool I like how your brain works did you cover in construction paper or poster board they are two different products in Canada I made a wing out of poster board and it was heaver than the same wing out of foam what is your final weight and the fan cover as a cowl is to cool thanks for shareing
brianm311 on August 1, 2014
sorry i haven't replied sooner the final weight is around 1430g's as far as the paper i want to say it is poster board little thicker than construction paper, it is the same material i used on my ft for the rear turtle deck. and the fan cowl works great an it recycles old stuff that would normaly be thrown away!! again thanx!!
Sharky on July 27, 2014
Thanks for answering a few questions I had, I am going to do a wrap with just the foam (no paper, peel it off) then going to use a process I saw on youtube using thin masking paper n white glue then light sand n paint. Pat yourself on the back bro you did a gr8 job congrats!
brianm311 on July 27, 2014
thank you very much!! i did a foam wrap (l-19 bird dog) i used a very thin foam and than covered it in thin yellow lens repair tape, it had a few wrinkles but looked good none the less, good luck with yours and send a link with some pics would love to see it !!
treeseatmyplanes on August 2, 2014
Beautiful build! The wooden stringers on the sides are a great idea. I'm sure they add a lot of strength and durability. I'm thinking another one on the bottom would make it even better. I'm definitely going to try this technique!
brianm311 on August 13, 2014
thank you! it works well, i did put a smaller spar on the bottom next time i think io might do like i did on the sides just for more support in the tail section,
brianm311 on August 2, 2014
thanx! on the top and bottom i was going to cut a full length one to go down the body but i opted to use popsicle sticks insted to try an lessen the weight they do add strength and also allow a place to attach the outer covering. again thanx!!
flyguy99 on August 17, 2014
Hi I really like this plane and i was wanting to know if you had the plans for it
brianm311 on August 18, 2014
thank you! unfortunately i do not have plans,only ideas in my head, i put as much info that i could in the picture section most of my measurements are in there so sorry i have no plans for you
dharkless on August 13, 2014
Very nice build. It is kind of mixed media, going back to some of the old balsa methods. Very nice finish and detailing.
Someone once said a plane that looks good usually flies good too. Some truth to that I think.
thak you!! this has become one of my fav's to fly now and find i bring it with me whenever i go flying. again thanx
Yogenh on August 15, 2014
I know I would love to have one
brianm311 on August 15, 2014
thank you!!
Yogenh on August 16, 2014
HEHEHE Would you build me one just like it????? LOL
you are not the first to ask !! lol my friends i fly with want one as well!!
Yogenh on August 18, 2014
Well that is what happens when you do such a great job. Just keep it going!!!
brianm311 on August 19, 2014
again thank you!!
