Spidex MICRO from Quaternium Multicopters!
by Zatoichi | December 8, 2013 | (6) Posted in Reviews
Spidex MICRO from Quaternium multicopters
Motor distance.
220mm diagonal, 145mm front to back and 165mm side to side.
http://quaternium.es/en/frames/71-spidex-micro.html
Recommended setting:
- 5" props
- Multistar 1704-1900Kv
- Blueseries 12A
- 1000mAh 3S
- RX 5.8Ghz  600mW - 200mW
- Mobius HD
- Naze32
 The Spidex micro put through it's paces by the skilled hands of Abormor
When jlcortex ,(jlcortex @aeromodelismovirtual.com)one of the best designers of multicopters on earth,offered to ship me one of his new designs to try,I jumped at the chance!
This Spidex micro quad is a little guy! Only 215mm motor to motor and 70mm tall!
This simple and durable frame is CNC machined from a single billet of POM-C.
Designed specialy for the Mobius HD camera it can fit a second analog FPV camera to avoid latency of digital cameras.
My build started by snipping this frame out with some nippers and sanding marks down in a spot or two.
Ok so, 10-15 minutes later you end up with this.
Ok here is the cool part...
You fit it together with the locking tabs and using no tools you have this!
That is it. Frame is built.
Pretty cool if you ask me!
A place for all yo stuff!
Did I mention it's tiny?
The base of the frame in mine is upside-down to fit the rcx motors.( Thanks abormor!)The frame is designed for the Multistar 1704 from HK.
Ok time to get going! Woot!
ZMR 1804 2400kv motors
RCX 10A ESC Brushless Motor Speed Controller (G Series / Programed for Multicopter - SimonK Firmware)
MWC MultiWii SE v2.0 Flight Controller (w/ Bluetooth Module Adapter)
Here are the battery bay dimensions.
more numbers...
Camera tab hight...
It is snowing out so I am off to build this baby up!
Stay tuned in for part two! =P
                                                    ZATO
casehatter on December 8, 2013
way cool looken forward to the flight might have ta get ya to hook me up with this critter..!!
efbe on December 9, 2013
Pictures disappeared ??
Efbe
Zatoichi on December 9, 2013
Um..They work for me Efbe. How about now?
MT Alex on December 9, 2013
No pictures for me, either, other than the first one. Tried IE 11, Firefox and Chrome.
Any luck now guys? =)
efbe on December 10, 2013
It OK for me now.
Zatoichi on December 10, 2013
Cool guys. Thanks for the heads up!=)
Thank you guys I will re-upload them! Sorry for the glitch
MT Alex on December 10, 2013
This is a pretty exciting little airframe. I'm glad to see you using an alternative flight control, I didn't find anywhere to get the Naze32 it calls for.
Zatoichi on December 11, 2013
My bro got some Naze, I got this one to see what we like better. I fixed the links above. Better hurry tho.=)
MT Alex on December 11, 2013
Thanks a bunch!
De nada,hermano!
Zatoichi on December 8, 2013
I can not wait to get this quad in the air! I hear that they are very hard to break. =) That makes it great for a fella such as myself. Last time I looked Case, they were going for € 40.00
That is around $50. If it is as tough as has been reported then that is a heck of a bargin! http://quaternium.es/en/frames/71-spidex-micro.html#sthash.N1YTSBVE.dpuf
