Tutorial:
Simple FPV race pylons
This tutorial will walk you through how to make cheap (2 for less than $3), easy, quailty FPV race pylons that are great for 250 class races.
Materials:
- Pool Noodles (any will work I got mine at Dollar Tree)
- Dollar Tree screw drivers (you get 2 for $1)
- Electrical or colored tape (optional)
A blurry photo of noddles and screw drivers.
INSTRUCTIONS
- Put screwdiver in one end of the noodle with metal end sitcking out.
- (optional) Wrap Noodle in colored tape. <--- This will make it easier to see in FPV goggles.
- Repeat
Results:
One pylon with tape and one without. Personally I prefer the taped version.
Conclusion:
These pylons are a ton of fun to use for FPV race courses, and are a good subsittute for feather flags. I find that they work well with disc cones, when designing race courses. If you happen to hit one with a multirotor, it will probably just bounce off. The most damage that these have ever done to my racer is a few broken props. I have also found that you can tape two together in the center to make a gate that will stand as long as it is not too windy.
Gate and pylons.
Thanks for reading!
also add in the small marker sports cones as the course line...
like these.. http://www.ebay.co.uk/itm/TRAINING-MARKER-CONES-Set-of-50-PE-Boundary-Markers-Athletics-Sport/190863902659?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D32694%26meid%3D69c5736898b84da387a7b86eb6a579ca%26pid%3D100005%26rk%3D3%26rkt%3D6%26mehot%3Dpp%26sd%3D111749415266
