Replacing DT750, DT700, DT900, DT1000 shaft
by tecdux | May 12, 2013 | (0) Posted in How To
After an accident with the octo, i've got 2 motors shaft broken. Since there isn't a replacement shaft, i bought one of the following shaft and use it with the DT750. The steps for DT700, DT900 and DT1000 are similar:
ะค4.0x67.0mm Motor Shaft for A3548 Series Motor
http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=544&productname=
It works flawless! =)
apache64 on May 13, 2013
I love your videos but this one has no sound, could you re-upload it please? otherwise I can make out what your doing, but some narrative would help, keep them coming..!
tecdux on May 13, 2013
thanks ;)
unfortunatelly they don't have sound because my house is under repairs so I've got a lot of noise
Gopherdave on August 8, 2013
Hello:
I use a small socket that the shaft just fits into resting on the vise to support the bell as I drive out the shaft. I've bent bells by not supporting the hub and don't forget the locktite for the set screw. I just did this to 7 dt750's, I wish they sold them with a straight shaft or bolt on prop adapter. i hate the threaded end, it's going to break there for sure. This is actually and easy repair, the trick is to use a heavy vise to work on and use firm direct taps on the shaft. If you pound hard on the shaft it will flare out and not fit out of the hole. Patience is your friend as shown in the video. This video is good to illustrate that it is easy to fix a broken or bent shaft, you don't have to chuck the motor.
