OrangeRx RX3S V2 Stabilizer - Delta Setup
by ProjectFlightDesign | May 30, 2013 | (6) Posted in Tips
How to setup a delta wing with the OrangeRx V2 Stabilizer unit. This unit has onboard delta mixing, so start off by disabling any delta mixing that you have programmed.
Link to stabilizer: http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=28456&aff=238467
https://sites.google.com/site/projectflightd/
- Rx: Using male-to-male servo wires, hook up the Elevator and Aileron controls from your Rx to the stabilization unit's Ele and Aile ports
- Stabilizer: Plug in your right control surface to Ele and your left control surface to Ail-L (right and left control surfaces as you look at the plane from the nose). Then flip the dip switches to the left for Ail, Ele, and Delta. [if your servos are lying down (mine are upright), you need to leave both ELE and AIL L set to NORMAL, rather than reversing them - thanks Flash5Cartooning!]
- Tx: Reverse your elevator output.
That's it! Hope this helps. Let me know what questions you have.
(I think that this should work for all transmitters, but I am using a Dx7se and can't verify this!)
sailorJohn on June 1, 2013
What kind of stick mount do you have on that motor
ProjectFlightDesign on June 2, 2013
I got it from HeadUp RC - http://www.headsuphobby.com/Plastic-Mounting-Stick-with-15-inch-base-plate-D-145.htm?categoryId=-1
Its great!
ghostrider03z on June 2, 2013
These work great also, $4 for 5! http://hobbyking.com/hobbyking/store/__9869__Electric_Motor_StandOff_Mounts_10mm_Small_base_5pcs_bag_.html
sailorJohn on May 31, 2013
I've been testing a orange stabilizer,turning the stabilizer on when flying can be bad, latest problem has been either a rec failure or delink, haven't torn into it yet. Be sure to have unit well fastened dble surface tape and turn it on when craft is level. sudden tail wiggle comes on for no reason.
jerimiah85 on May 31, 2013
are you getting tail wiggle when you set the gyro b4 take off or in the air? you may have your gain set way to high. if this is the case like mine was just turn them 1/4 and test fly to adjust the settings to your needs..
After takeoff, my settings are very low but when it is working properly it makes it possible to fly and land in very high wind( a low wing version of EA's NOOBTUBE).
jerimiah85 on June 1, 2013
Ive never built a noob tube. Looks like a fun plane tho.. Ive got to stay off these pages I keep finding Planes I fell I must build.
is this a scratch build wing?
ProjectFlightDesign on May 31, 2013
Yep! My design! Being flown by a bunch of people on youtube (like rctestflight)
https://www.youtube.com/watch?v=-3UKcL49dvs
https://www.youtube.com/watch?v=lpjzNjn7ynw
Ok just got done with this thing. Looks Great I like your fpv video so I went ahead and Build a powerpod for this one. hope to make it look a little cleaner. hope to fly sat . thanks for the links the build video helped a lot as I could not get the pdf to load.. thanks again
Thanks buddy im going to build this tonight. ive never had a wing but Ive flown pusher jets and the ft delta so im sure this is going to be a blast
