*For all links metioned in the video, please scroll to the bottom of the article.
Josh and Eric are back with the Naze 32 Setup this week.
With the Naze being a fan favorite for race quads, we will be using one on the Electrohub. Eric made this one special.
Most boards come without the pins soldered in, so Peter helped walk through the process of getting the board ready for programming.
Eric and Josh cover what you will see when plugging in the board for the first time, and explain how to select the proper configuration.
Eric made the arms for the Quad special, and are now on our store! Check them out and pick up your own pair!
Eric explains how he set up his arming switch, as well as Atti and Manual flight modes.
The race quad handles better then expected! Easily zipping around at a good pace.
The Naze works well for acrobatics, easily doing forward and backward tumbles, as well as rolls.
With this being a basic Naze setup video, we will be working in the future with more tips on the board.
Click here to download the full Naze32 Manual
For Balancing your Props, check out the article here: http://flitetest.com/articles/balancing-props
For Oscar Liang's in-depth article on PiD tuning, click here: http://blog.oscarliang.net/quadcopter-pid-explained-tuning/
For the Drivers needed to pull up the Naze Board on your computer, clikc here: http://www.silabs.com/products/mcu/pages/usbtouartbridgevcpdrivers.aspx
Keep up the GREAT work flitetest crew!
Where can I get one of those covers to put on the electrohub? Looks pretty cool!
Thanks
http://forum.flitetest.com/showthread.php?20293-Dome-for-electrohub&highlight=electrohub+dome
Thaks
Thanks
I have to admit I chuckled at the sight of you guys using a "Bixler puft-pack" battery for your quad! LOL!
I would also like to see a Naze32 set up for the spider quad.
Thanks
Eric tells he has been hours on the skype-phone with someone to be able to tune the naze32 ...
Then how is it that it is considered such a straight-forward FC?
Why should we choose it?
Here is the code (sorry, just a link into my codebase) that makes that transition:
https://github.com/Crashpilot1000/TestCode3/blob/master/src/mw.c#L844
And here is the part that "calculates" the proportional factors:
https://github.com/Crashpilot1000/TestCode3/blob/master/src/mw.c#L819
You may notice that I reduced the range for the angle mode so rate mode takes over a little quicker - better flips in horizon mode on my setup :)
Cheers Rob
One example that comes to mind is adding a Sonar altitude limiter - I can't wait to try this. HK has them for about $3-4. http://www.hobbyking.com/hobbyking/store/__31136__Ultrasonic_Module_HC_SR04_Arduino.html
That's crazy cheap for something that, if it works well, could stop a noob from pile driving his shining new special bent arm quad straight into the ground.
Here is a video -https://www.youtube.com/watch?v=seVDPjSFRrE
What do you think?
Thanks
The other thing that I found is that as I only have a very basic 6 channel radio with no screen or detailed limit adjustments I couldn't get the board to arm using sticks until I changed the mincommand settings on the board. Hope that helps some other newbies.
Not quite as convenient to use as bluetooth, but also requires no extra components on the Naze.
I'm starting to cut my own carbon for a mini quad of my own should not be too hard to make angled arms out of carbon would need the thickness and angle so I can match them.
I can cut 3d as well so might have a go at cutting wedges for carbon mini quads.
kendrick
Thanks in advance!
Eric explains the process in the Electrohub Y6 Build video.
Naze32 Acro V1.7.0 / Cleanflight
2300KV Cobra motors
12amp T-Motor esc's Simon K
6x4.5 HQ carbon reinforced props
Thats what he is using
I did run into a problem where I couldn't get the initial connection made -- I kept getting a "no response from bootloader" error from Cleanflight.
I found the solution here: https://www.youtube.com/watch?v=nVF-gQsUu50
Thanks, again, for a great kit and build videos!
I fixed it by watching this video(https://m.youtube.com/watch?v=W0vOVZPzIMo)
It must be difficult fitting all the info into a short video.
The Flite Test guys do a great job though.
Thanks
15.8 seems very high compared to all other settings that I have seen
Should I be concerned.
Thanks for everybody's hard work
