Long Range Mod On Spektrum For $10!!!
by FoamyRC | February 26, 2016 | (0) Posted in How To
 This is going to be showing you how to get long range on spektrum controllers for very cheap. This is a very easy mod to do and it should work for most spektrum remotes. The parts you will need is 1 2X U.FL Mini PCI to RP-SMA Pigtail antenna wifi cable, and 1 TP-LINK 2.4GHz 8dBi Antenna. All you will need for tools is a screwdriver and some sort of saw (bandsaw works good). This should only cost around $10. Don't forget to subscribe to our youtube channel FoamyRC
This video will show this mod in action and also show you how to build it.
1. You are going to want to remove these screws on the back.
2. Pull off the antenna cover (you might need to use a little force).
3. Be careful though because there are wires inbetween the top and bottom plate.
4. For this step you are going to have to use your saw to cut off the black piece that is protruding out. Then just unplug the old wire and put the new one on.
5.  Tighten the RP-SMA plug than put the screws back on. Then all you have to do is screw back on your antenna and you will be ready to fly.
When your done with this mad you should get around a 2 miles of range. Compared to stock it is way better. We are working on another mod right now that sould get you around 3 miles of range. If you want to see that don't forget to subscribe to our youtube channel FoamyRC.
AERODROME on April 21, 2016
UNDER THE NEW FAA REGULATIONS YOU DO NOT NEED ALL THAT EXTRA RANGE. 400 FEET UP AND LINE OF SITE FLIGHT. ADDITIONALLY THE FCC CERTIFIES TRANSMITTERS FOR ERP. .
THAT BEING SAID, I AM IMPRESSED BY YOUR SKILLS.
Mostly Harmless on April 20, 2016
Not a bad idea.
But keep in mind that antennas don't really make more output power from a transmitter. They can only take the existing transmitter output power that goes in all directions and concentrate it in a narrower range of directions. Typically, a longer antenna like the one shown here will concentrate more of the power perpendicular to it. In other words, while your radiated power might be stronger off the side of a longer vertical antenna, there will be less power radiated off its ends.
This isn't necessarily a problem, but you do need to realize that your range will increase in some directions (relative) to the antenna, but decrease in others. It will become a problem if you inadvertently turn the transmitter so that the antenna is pointing towards the aircraft -- lowering the amount of power radiated in that direction... it could be enough to cause a signal dropout.
Side note: These WiFi antennas are effective because most WiFi users are roughly at the same altitude as the wireless routers they access -- the power output is increased in the horizontal directions, but decreased vertically.
The-One-Who-Never-Crashes on April 21, 2016
Very good point on the directional aspect of these antennas. About the power output being increased horizontally and reduced vertically, I think it'll just keep us under 400 feet :D!
CAUTION! LOOK UP ESD ON GOOGLE.
pintokitkat on April 22, 2016
But then we don't all live in the USA under the authority of the FAA.
ludodg on April 26, 2016
word!
Frosty0_0 on August 28, 2018
Could you write a follow up on the success of the modification?
