FTScratchBuild-Advanced
The day is here! We finally have the plans available for the Kraken.
FREE PLANS
SUPPLEMENTAL VIDEOS
This kit is so big that it wouldn't even fit in one screenshot. The Speed Build Kit will be available sometime early August.
Also, keep your eyes open for tons of cool accessories incoming!
Measurements for landing gear wire
18" long x 1/8" thick (45cm long x 3.18mm thick)
Bends are 2" (5cm) and 6" (16cm)
Links for tires incoming!
A big ol' wing needs a big ol' battery!
We've been using this 6000MAh made by Gens ace. This can get you close to a half-hour of flight time and is impressively light for its size.
RECOMMENDED ELECTRONICS
- Motor: 2x Suppo 2217/7 1250kv Brushless Outrunner
- ESC: 2x Suppo 30A Brushless ESC
- Servo: 2x GS-9025MG Micro Analog 11g Metal-Gear
- Prop: 2x APC 10x4.7 Slow-Fly
- Battery: 2200 - 6000 mAH 3s
- 4x 12" Servo Extensions
FREE PLANS
Hope you all have as much fun with this plane as we do! Go crazy! See what kind of trouble you can get this monster into. Post some photos or videos on the forum page!
Thanks guys
You waited Years. You thought You'd NEVER see IT. BUT Science has Bought IT to You Now...
We NOW Give YOU The (drum roll)............ D FOLD!!!
The ONE and ONLY Flite Test FOLD that uses a DOULBE Wide RELIEF to create a Paper Protected and Glue Reinforced DOULBE THICK FOLD (echo)...
IT's STRONGER. IT's TOUGHER. IT's LIGHTER. IT's BRIGHTER. IT's WHITER than ever BEFORE.
Get YOURS Today!
Well done!
I agree, I just wish Josh Scott could be around in Flite Test more often. But, he is a busy man...
Long time RCer. First time FliteTester.
Josh B. Said that he was using an Art Tech glue gun. Did he mean Ad Tech?
Also, is the recommended motor the same one as in the "BEEF" setup?
Got it down to 35 pages and added grid lines to help make everyone's build go smoother. I also removed the duplicate pieces so you'll need to flip some of the templates over for the second piece.
Condensed plans:
https://www.dropbox.com/s/g2e4tqxbrbs9t3e/Kraken.pdf
Check my post further down I have converted the plans to 8 pages of A1, no change in size or shape no sheet joining required.
Just have to work out how to upload the plans.
Kendrick
https://www.dropbox.com/sh/e4cq4qt1fgh4qai/AABkxBUj3UPngkcveUunBRLwa
I broke down the pieces into their own sheets of 20x30in or less so each section will fit on one sheet of DTFB. I also removed the duplicate pieces so you'll need to flip some of the templates over for the second piece.
Dave
1. Open the PDF you want to print using Adobe Reader X.
2. Click the Print icon.
3. In the Print dialog box, click Poster.
4. Set Tile Scale to 100%.
5. Set Overlap to 0.005in.
6. Click Print.
Dave
I have been using my desktop publisher to alter the layout of the plans to fit smaller sheets of paper without joining any sheets together.
As I am in the UK I used the A size sheet, I have done a version that fits on 8 A1 sheets each sheet is slightly bigger than 20x30 inches the size of dollar tree foam board, I had a printout made and it works, I still have to tweak a few lines so they join but the size and shape work as is. I can alter the page size to find to print out but slightly bigger than the foam board seamed like the best size to choose.
Anyone interested in a copy of my resized plans.
Kendrick
I'll work on getting rid of the gaps in the lines that I found when I printed my version out.
Then I'll have to work out a way to post it.
Kendrick
Caution - Never set the glue gun down on it's side! Hot glue will move to the side and jam the glue stick. ( happened when I was gluing the leading edge of the top and bottom skins on one side. The wing's curvature is slightly different if you look closely, flys great)
Axel
Thanks a bunch guys!
https://www.dropbox.com/sh/qgrwlwbqlezhclk/AABEHAEpi5dxGK-k7VdPbLrFa
1. What are the materials in this build, and the other foam builds? What is this foam? Where do I buy it? What is the thin wood that they use? How about the piano wire? (where do we get these materials)????
2. How do we use the plans as a template to cut the foam pieces? Tape it on the board and then cut/score? If so, what is the best way to print out the template? 64 pages of 8.5x11 paper that we tape together? Take it to a print shop on a larger sheet??
Since a lot of their plans use these materials and these methods, I'd love to find a central place to have questions like this answered!
Thank you, all.
Some Build Photos
https://www.dropbox.com/sh/sos0oygdhq81fr4/AADnkYqviDBTtTClRn0V6bm-a?dl=0
One question though: you guys mention in the build Video to make Sure the Servos have a Metal Gear. Since you recommended that, I'm assuming the Option "Power Pack C (Fixed Wing Large)" I just added feature those, right? Can't really tell by the description of the content.
I'd have ordered the Lighting strips too if they were available through your shop, maybe you guys should talk to hobbyking about that. That Look of the lit wing is what I'm after.. whish me luck.
If that plane flies as smooth as the Videos make me think, this will be an awesome Product to keep..
Axel.
Question I decided to make My Kraken a Pusher with twin rear wheel steering a Carbon fiber arrow going vertically down about 4 inches in front of motor I left the shaft long enough that it sticks up about 4 inches above top of plane in front of prop. would a Rudder in front of a pusher have any effect during flight ?
The sizeof the 2x 2217/7 1250kv motor need - CW or CCW?
Has anyone else encountered this problem? Found an easier method of sorting and joining the 64 tiles?
sp
