Flight Stability Gyro / Accelerometer Filter
by nickatredbox | April 20, 2013 | (4) Posted in Tips
Kalman Filter for Arduino and C# Test Harness
Kalman filter test harness with mimic C# code converted from Arduino code originally writen by Kristian Lauszus, TKJ Electronics.
Here is the Arduino code for same Arduino Code
The filter inputs in the test harness are driven from the sliders but could easily be fed from a real sensor. Another day perhaps?
The whole project is here Kalman Test
The C# class
/* Copyright (C) 2012 Kristian Lauszus, TKJ Electronics. All rights reserved.
 This software may be distributed and modified under the terms of the GNU
 General Public License version 2 (GPL2) as published by the Free Software
 Foundation and appearing in the file GPL2.TXT included in the packaging of
 this file. Please note that GPL2 Section 2[b] requires that all works based
 on this software must also be made publicly available under the terms of
 the GPL2 ("Copyleft").
 Contact information
 Web      :  http://www.tkjelectronics.com
 e-mail   :  kristianl@tkjelectronics.com
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
namespace KalmanTest
    public class Kalman
         /* variables */
        double Q_angle; // Process noise variance for the accelerometer
        double Q_bias; // Process noise variance for the gyro bias
        double R_measure; // Measurement noise variance - this is actually the variance of the measurement noise
        double angle; // The angle calculated by the Kalman filter - part of the 2x1 state matrix
        double bias; // The gyro bias calculated by the Kalman filter - part of the 2x1 state matrix
        double rate; // Unbiased rate calculated from the rate and the calculated bias - you have to call getAngle to update the rate
        double[,] P =  new double[2,2]; // Error covariance matrix - This is a 2x2 matrix
        double[] K = new double[2]; // Kalman gain - This is a 2x1 matrix
        double y; // Angle difference - 1x1 matrix
        double S; // Estimate error - 1x1 matrix
        public Kalman() {
            /* We will set the varibles like so, these can also be tuned by the user */
            Reset();
            // Reset bias
            // Since we assume tha the bias is 0 and we know the starting angle (use setAngle),
            //the error covariance matrix is set like so - see: http://en.wikipedia.org/wiki/Kalman_filter#Example_application.2C_technical
            SetDefaults();
        // The angle should be in degrees and the rate should be in degrees per second and the delta time in seconds
        public double getAngle(double newAngle, double newRate, double dt) {
            // KasBot V2  -  Kalman filter module - http://www.x-firm.com/?page_id=145
            // Modified by Kristian Lauszus
            // See my blog post for more information: http://blog.tkjelectronics.dk/2012/09/a-practical-approach-to-kalman-filter-and-how-to-implement-it
            // Discrete Kalman filter time update equations - Time Update ("Predict")
            // Update xhat - Project the state ahead
            /* Step 1 */
            rate = newRate - bias;
            angle += dt * rate;
            // Update estimation error covariance - Project the error covariance ahead
            /* Step 2 */
            P[0,0] += dt * (dt*P[1,1] - P[0,1] - P[1,0] + Q_angle);
            P[0,1] -= dt * P[1,1];
            P[1,0] -= dt * P[1,1];
            P[1,1] += Q_bias * dt;
            // Discrete Kalman filter measurement update equations - Measurement Update ("Correct")
            // Calculate Kalman gain - Compute the Kalman gain
            /* Step 4 */
            S = P[0,0] + R_measure;
            /* Step 5 */
            K[0] = P[0,0] / S;
            K[1] = P[1,0] / S;
            // Calculate angle and bias - Update estimate with measurement zk (newAngle)
            /* Step 3 */
            y = newAngle - angle;
            /* Step 6 */
            angle += K[0] * y;
            bias += K[1] * y;
            // Calculate estimation error covariance - Update the error covariance
            /* Step 7 */
            P[0,0] -= K[0] * P[0,0];
            P[0,1] -= K[0] * P[0,1];
            P[1,0] -= K[1] * P[0,0];
            P[1,1] -= K[1] * P[0,1];
            return angle;
        public void setAngle(double newAngle) { angle = newAngle; } // Used to set angle, this should be set as the starting angle
        public double getRate() { return rate; } // Return the unbiased rate
        /* These are used to tune the Kalman filter */
        public void setQangle(double newQ_angle) { Q_angle = newQ_angle; }
        public double getQangle() { return Q_angle; }
        public void setQbias(double newQ_bias) { Q_bias = newQ_bias; }
        public double getQbias() { return Q_bias; }
        public void setRmeasure(double newR_measure) { R_measure = newR_measure; }
        public double getRmeasure() { return R_measure; }
        public void Reset()
            bias = 0; // Reset bias
            P[0, 0] = 0; // Since we assume tha the bias is 0 and we know the starting angle (use setAngle), the error covariance matrix is set like so - see: http://en.wikipedia.org/wiki/Kalman_filter#Example_application.2C_technical
            P[0, 1] = 0;
            P[1, 0] = 0;
            P[1, 1] = 0;
        public void SetDefaults()
            Q_angle = 0.001;
            Q_bias = 0.003;
            R_measure = 0.03;
    }//End of class
The whole C# project is here Kalman Test
Here is the Arduino code Arduino Code
Contact information
#ifndef _Kalman_h
#define _Kalman_h
class Kalman {
public:
   Kalman() {
       Q_angle = 0.001;
       Q_bias = 0.003;
       R_measure = 0.03;
       P[0][0] = 0; // Since we assume tha the bias is 0 and we know the starting angle (use setAngle), the error covariance matrix is set like so - see: http://en.wikipedia.org/wiki/Kalman_filter#Example_application.2C_technical
       P[0][1] = 0;
       P[1][0] = 0;
       P[1][1] = 0;
       /* Step 1 */
       angle += dt * rate;
       /* Step 2 */
       P[0][0] += dt * (dt*P[1][1] - P[0][1] - P[1][0] + Q_angle);
       P[0][1] -= dt * P[1][1];
       P[1][0] -= dt * P[1][1];
       P[1][1] += Q_bias * dt;
       /* Step 4 */
       S = P[0][0] + R_measure;
       /* Step 5 */
       K[0] = P[0][0] / S;
       K[1] = P[1][0] / S;
       /* Step 3 */
       /* Step 6 */
       angle += K[0] * y;
       bias += K[1] * y;
       /* Step 7 */
       P[0][0] -= K[0] * P[0][0];
       P[0][1] -= K[0] * P[0][1];
       P[1][0] -= K[1] * P[0][0];
       P[1][1] -= K[1] * P[0][1];
       return angle;
   void setAngle(double newAngle) { angle = newAngle; }; // Used to set angle, this should be set as the starting angle
   double getRate() { return rate; }; // Return the unbiased rate
   void setQangle(double newQ_angle) { Q_angle = newQ_angle; };
   void setQbias(double newQ_bias) { Q_bias = newQ_bias; };
   void setRmeasure(double newR_measure) { R_measure = newR_measure; };
private:
   /* variables */
   double P[2][2]; // Error covariance matrix - This is a 2x2 matrix
   double K[2]; // Kalman gain - This is a 2x1 matrix
#endif
Supergoldfish on April 20, 2013
Great idea! I've built a sentry gun as a past project using the kalman filter with great success. Now you got me wondering about how well it work in this application.
nickatredbox on April 21, 2013
I'm told its pretty well used by people on DIYdrones also there are plenty of demos on Youtube with IMU's
sailorJohn on April 21, 2013
Wow!
cwozny on April 21, 2013
I'm still trying to find a white paper on fusing a magnetometer into the gyroscope and accelerometer Kalman filter.
perhaps have 2 stages using the derivative of the first stage output
stage 1 -= gyro / accel
stage 2 = derivative of stage 1 / compass
I have not seen one either
stage 2 = stage 1 / compass
