How to replace DT750 DT700 DT850 bearings
by tecdux | January 28, 2013 | (8) Posted in Tips
I've done a video showing me disassembling the DT750, changing bearings and then reassembling it:
I was getting lots of vibrations from my Hextronik DT750 even after balancing it and using balanced props. I replaced the bearings and now the motors are like new!
The steps for DT700 and DT850 are similar
PabloJaime on January 29, 2013
Nice tip!!!
tecdux on January 30, 2013
Thanks! ;)
mdrm on January 29, 2013
What bearings are used??
HK450V2 Bearing (8x4x3mm)
Internal diameter: 4
External diameter: 8
Height: 3
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11521
colorex on February 3, 2013
Is that listing for 1 or 4 bearings?
tecdux on February 4, 2013
4 bearings ;)
sailorJohn on March 29, 2013
My bearing (Rear) did not come out easly,took it out in pieces. Motor runs but is suspect.Himax 850
tecdux on March 31, 2013
I had some bearings with this problem too, I used a screwdriver to take them out ;)
danallen82 on July 9, 2013
Would you consider using another bearing from the start? Like a high end japanese bearing?
It seems these motors are plagued by that issue.
Budge72 on July 13, 2013
It was recommended on another thread about this issue to find some Boca Bearings and give them a try. I plan to oil my original bearings by soaking them overnight . If those don't perform, I found some Boca Bearings at my local hobby store for $1.50 each.
tecdux on July 14, 2013
yes, boca bearings is an alternative
i searched for skf bearings but unfortunatelly they don't have this size
