Hobbyking Q-Bot and the Aurora 9
by LordOtter | April 28, 2013 | (0) Posted in Tips
How to wire the Turnigy Q-Bot Tx to the Aurora 9.
- Remove the HiTec module (alredy done as I'd fitted the Frsky DHT)
- Use a female/female servo lead to attach Tx to A9, pins L>R: signal, +ve, neg/ground
- Do not power up the TQ-Bot Tx, it gets power from the A9 when it is switched on
- Switch on A9, you have 10" to connect battery on the Q-Bot quad.
Programming controls were:
Ail: NOR
Ele: REV
Rud: REV
Thr: REV
No Comments Yet
Be the first to leave one!
