Hansa Jet: the lost German jet (now RC!)
by Keenan smith | February 21, 2014 | (23) Posted in Projects
The Hamburger Flugzeugbau HFB-320 Hansa Jet was an all-metal, twin-engine, 10-seat business jet that was built by German aircraft manufacturer Hamburger Flugzeugbau between 1964 and 1973.
The most notable feature of the aircraft was its forward-swept wing, which was mid-mounted in the fuselage. This arrangement allows the wing spar to pass through the fuselage behind the passenger cabin without decreasing cabin volume. As of 2011, it remains the only civilian jet ever to use a forward-swept wing.
The jet was last known to fly in 2009 with the Luftwaffe (German airforce)
The jets interesting shape, uniqueness and on top of all the Forward Swept Wings appealed to my sense of adventure and after much hunting around I found no evidence of there ever being an RC model of it, this sparked my build instinct :p and so started this project.
The first thing I set about was finding a 3 view and after much searching I found this 3 view and a reference drawing
So after scaling up and much math I decided upon a 44" wingspan jet and set about building it.
First I cut floor panels and added formers, shortly followed by some skin panels.
Then I began building the wings, sizing up and guesstimating the correct size and shape of the control surfaces, placing spars, ribs, so on so forth.
I then began cutting the rudder and building the elevator,
The next step in the process was to build the rear half of the jet in order to support the tail.
Then I set about building the lower half of the fuselage and squaring-up the fuselage and wings.
After much thinking I had settled on the fowler method for hinging the flaps and mounted them and they're hinge fairings.
I took the liberty of building a scale cockpit too while I was at it
The next step was to carve and gradually sand and carefully shape the two tip tanks to which where then attached to they're respective wing-tips
When my fans and landing gear arrived I immediately set about installing my retracts so I could set the bird on her feet!
I then begun the task of soldering up mating up her twin 50mm Changesun 11blade fans to the 50A Red brick ESC's ( I have only ever had good results with red brick ESC's) and soldering on the connectors.
Afterward I mounted the power system and took some beauty shots! ( how artsy! )
there is some ply wood mount plates for the landing gear hidden within the foam Superstructre and can be barely seen when viewed from above
The next step was to build and mount the slat mechanism, which was relatively simple and had good results.
Now that my main gear was in I set about building the belly fairing ( that the gear retracts into), I started by first placing formers and then a few stringers to build up the shape of the belly fairing,
When my carbon arrived I set about bracing the wings to prevent too much wing flex and also to hold the correct amount of dihedral.
After more beauty shots I weighed her to work out roughly what the wing loading would be and to find out roughly what the AUW would be,
The two turnigy 2200Mah 3s 30C Lipo Flight packs
Total is looking at around (3.5lbs)
Seems like the wing loading will come out at about 20oz/sq.ft so still pretty light
Still gotta add nacelles and remaining skin panels
Being curious I took her out for a Taxi test in the midst of the night and begun a few high speed taxi runs to which on one she hopped into the air ( butt clench moment as she doesn't yet have her flight controls) flew a few feet (at 40% throttle) and settled down gently in the short grass...
here is a short video of the Second Taxi test
it was mostly filmed at 60% percent throttle and above
she seems pretty nippy and i absolutley love the sound of these Fans!!
they have a nice Whoooooooosh....
im beginning work on the nacelles this weekend as i have printed and cut-out the templates :)
also in other news an engineer freind of mine at Teledo Airfeild managed to snap a few pics of the last surviving US Registerd Aircraft (it was a Grand Aire Cargo Aircaft)
More progress
31/3/14
Got some major skinning work done and built the nacelle framing
i closed up the wings and added the balsa leading edges, the wing is ten times stiffer now (i can pick up the aircraft fully loaded by the wing tips and the wing seems plenty stiff torsionally)
i then set about CG'ing the Aircraft
With the CG Set on the main Spar the batteries sit just infront of the Wings LE which works out perfectly for me.
i then began sheeting the nacelles with some 3mm Depron
i still have yet to add the intake lip but id say it looks good so far
i then set about reshaping the tail cone to better resemble the real thing
i still need to figure out how to make the bump on the tail cone after sheeing the tail and add the ventral fins
i then began cutting the second nacelles skin panel
a little artsy beauty shot showing just how big she is
more updates to come soon so stay tuned for the completion and up and coming maiden!
Keenan smith
Willsonman on March 17, 2014
Good call on the CF bracing. One of the big challenges for forward swept wing designs is the inherent twist on the wing on attitude changes. If you build the wing rigid enough it will not be a problem. Looks like a fun project!
Keenan smith on March 18, 2014
the Wing is Nice and rigid!, and with the plane being designed as Semi - monocoque the skin takes alot of the load (so it'll get stiffer when i close up the wing :) )
lets just say i over built :P
K
alibopo on March 17, 2014
A real labour of love - I'm well impressed! Can't wait to see the flight footage. I reckon with a model like this I'd have more than just butt-clenching going on if I was trying to fly it - my hat's off to you. I must admit I was searching the photographs for more 'structural interfaces' between the more solid bits (landing gear, etc) and the foam superstructure/shell. I was expecting to see something like balsa lamination onto the foam to help spread forces away from these areas of 'possible' force concentration - is there additional stiffening that's not so obvious?
yeah, where the landing gear mounts there is some sandwiched ply inbetween two layers of 3mm Depron... also there a some r-enforcements still left to go in
yup she been a labour of she is indeed
K
Keenan smith on March 20, 2014
ohh also there is a CF rod running from nose LG to MLG :)
K
Carmatious on March 17, 2014
It's so pretty!
yes, that why i wanted to take her on!, she has curves in all the right places like a good woman :P
k
RotateB4TheEnd on March 17, 2014
This looks fantastic. As soon as the Viggen came out, I have had thoughts of building an airliner like this. Can't wait to see the end result!
thanks mate!
spetnazer on March 17, 2014
Waowww....look great...very beautiful sir!
Thanks Spetsnazer
Michael9865 on March 17, 2014
Exciting. Looks good. I will be awaiting more updates. Thanks for sharing.
i have updated Now actually with a taxi test video
sailorJohn on March 18, 2014
I think we can all learn from his effort.
Thank you Sir!
K
updated ...
Gryf on March 18, 2014
Terrific build, Keenan! Amazing design, too... I'm looking forward to seeing it in the air.
Thanks gryf! Will keep on building!
Flying Penguin RC on March 18, 2014
5 Stars.. Can't wait to see this one in the air. Great job!
Thanks flying penguin! Neither can I
Ultimate_Red on March 18, 2014
This will be awesome if you gave it an accurate paintjob at the end. Keep up the good work K!
Thanks man Will do!!
spetnazer on March 18, 2014
Sound like great...Can't wait to see this one in the air Sir! Uuuyeeeeehhhh
Keenan smith on March 23, 2014
Your not the only one :p
Work on this project continues later today :)
Carmatious on March 22, 2014
Awesome!
BuckE67 on March 20, 2014
Wow! awesome detail! Very good job!
Thanks buck
Yogenh on March 20, 2014
It is great and how long have you been working on it? Are you going to put the plans up on here?
I hope to soon, but i need to finish this and make some tweaks before i post plans
Yogenh on March 23, 2014
That would be great and man you have done such a great job on it and I bet that you have been putting in a lot of time on it too.
Flying_Dementia on March 20, 2014
It looks awesome
#Respect..!!
Thanks man!
Keenan smith on March 31, 2014
31/4/14 Updates Added
Flying Fox on November 19, 2014
Awesome Mate
andy77 on January 14, 2015
Hello keenan smith, what you've done is incredible, awesome.
I wanted to ask you to send me the plans by email, please, please ..
You're a genius, I know you're a good guy, please.
here I leave my mail : andysmile93@hotmail.com ....thanks!!!!
