GoPro Lens Hood
by K2theM | May 20, 2014 | (0) Posted in Projects
I do aerial photography for the company I work for using a DJI Phantom w/ a GoPro Hero 3 mounted to a Zenmuse gimbal. The setup works nicely but I've had some problems with "scanlines" showing up during specific flying conditions. These lines appear when the propellers are just on the edge of the frame, and when the sun is in view. When this happens, horizontal lines are created that ruin the shot. Talking to my director about the issue, he said a Lens Hood might solve the problem. While his suggestion was good, no one makes a Lens Hood for a GoPro.
There are several hats I wear, and Multirotor/Drone Pilot is only one of them. Since I also do 3D CAD work and have access to a 3D printer, I decided to make my own.
After some trial and error this is what I have come up with:
While our printer resolution is somewhat large by todays standards, it gets the job done. I can film in both Wide and Medium shot angles without seeing the edges of the hood. The hood performs as promised, eliminating the scannlines. However, because it increases the frontal area of the camera, and is basically attaching a small sail directly to the lens, some Jello works it's way back into things. So there is a bit of a trade off. It's a good thing I made it press-fit so I could easily remove it as needed.
If you'd like your own, it's available at Shapeways here
UPDATE:
Still working as advertised but I'd add an additional word of caution: If you are flying in higer wind conditions be aware that the sail effect on the camera may overpower your gimbal.
apnewton on June 16, 2014
Very impressive, well done.
Sirglider on June 17, 2014
Interesting, but could you post a video or a couple of pictures to show the difference with and without your hood. Thanks for creating!
K2theM on June 19, 2014
I'll try. I'm just charged with flying the thing, so I'm not really set up to edit video. I'll see what I can do.
Pav on June 18, 2014
thank you
danallen82 on June 18, 2014
A big thanks for sharing the source model. My only issue with it is that there isn't a huge improvement on flare reduction with such a wide lens. IMO as another video guy, it would have been better to design one for the "Medium" 1080p crop on the GoPro.
It is designed with the "Wide" angle in mind (since that's what I'm normally shooting at).
Flares can still occur, but mostly my goal was to eliminate the scan-lines that appear when the blades tip just into frame. (I'm still trying to get the video for that. I am not the editor, so my machine isn't really set up for that.)
GoPro Lens Hood
