Go Big or Go Home! 4 Motor Scratch Build!
by brettp2004 | May 23, 2013 | (19) Posted in Projects
I have been building the Swappable series planes for a while now and had a bunch of parts laying around that weren't being used.  After seeing the FT Cruiser, my friend (RescueLoadMaster a.k.a. Ian) and I had an idea to do a 4-motor plane just to see if we could. We have both only been in the RC hobby for a little over a year, but after an evening of beer soaked initial planning this idea was born. I had four motors and ESC's sitting around from failed quadcopter attempts, so we tried to base it off of the B-17 but it kind of came out looking like a mix between a B-17 and C-130.
We started with the fuselage, which is an entire sheet of foam board that is scored and rolled to give it that rounded shape.
The wings are made like those on the Bloody Wonder but are made from two sheets of foam board and have a slightl forward taper on the trailing edge. We both have built the FT Bloody Wonder and love how stable the wing is. They're joined like the wings on the FT3D with a 4 inch gap in the middle for a little added wingspan and to allow room for the enormous wiring harness. The wing was by far the hardest part to make, largely because all of the electroncs are ran through the wing. To run the electronics we tied a metal nut to a piece of kite string and used a magnet to route it through the wings and then pulled our wires through. Our power wires are attached to all of the motors using 3.5mm bullet connectors so we can unplug and change things as needed.
There is also a nose cone to add a little length and area for future FPV equipment.
Once it's completed, it's three pieces that can be assembled easily at the flying field. All the pieces are held together with four BBQ skewers, two short ones hold the back of the wing in the fuselage and two long ones that connect the wing, fuselage and nose cone.  We glued light ply to all of the areas where BBQ skewers connected the pieces together to keep the foam from pulling apart.
Once assembled, it has a 64" wingspan, 42" length, and we got the CG perfectly aligned with the spar.  The ailerons measure 15"x2", the flaps are 12"x2", the elevator is 18"x2", and the rudder is 8"x2".  We figured is was better to go big with the control surfaces and if we needed to, we could always dial down the rates. The landing gear are the FT Cruiser design using 1/8th" wire.
The electronics are 4 DT750 Hextronic motors turning 8x6 props with 4 25A Turnigy Plush ESC's, there is a total of 7 servos that are all 9grams and we had 2 3S 2200ma Turnigy Nano-Tech batteries powering it all. We were flying with a Turnigy 9X with the FrSky module installed. It weighs about 2100grams and from what we could tell had about 1650grams of thrust. It's got ailerons, flaps, rudder, elevator, and steerable tail wheel mixed in with the rudder that is run by it's own servo. The power pods were the FT Swappable Power Pods only cut down to about half size as to not interfer with the control surfaces.
When it came time to maiden this monster, it only had about 5 feet of ground roll before it lifted off the ground.  Once in the air, it flew like a dream.  Believe it or not, we did not have to trim this baby at all.  In our minds it could not have flown better.
jd7792 on May 26, 2013
I love what you guys have done here, looks real good but you know you should go the whole hog and add some colour and nose art. I think it would look great with some military nose art from Hobbyking or somewhere like that! It would really add another dimension! Keep up the good work!
brettp2004 on May 26, 2013
We want to but we wanted to make sure it flew before we spent time painting it! Thanks for the input.
Jeez on May 25, 2013
Looks great in the air!
EndoftheRoadRC on May 28, 2013
Great job, like your fuse design
RescueLoadmaster on May 25, 2013
Thanks everyone, we had a blast putting it all together.
jerimiah85 on May 25, 2013
Awesome guys.
NoUsername on May 25, 2013
Super plane!
Splatwillicrash on May 28, 2013
Great job guys, really fun to see, and great to hear you guys excited about it as the thing flys. Now....As a Load Master, you KNOW your gonna have to put a ramp door on the thing.... From watching other videos I suggest you set it up so when the rear door opens a couple air scoops on the fuse open to help your cargo palet leave cleanly!!! Your nose art can be "Foam Core Air Corps"
RescueLoadmaster on May 29, 2013
We have already talked about a bomb bay or ramp and door, but put it off to do the test flights. I have a feeling we will keep tinkering with it and adding more stuff because it can handle a HUGE payload.
xjjosh on May 29, 2013
It needs some crazy fpv gear!
gmyers2112 on May 27, 2013
As I understand it, EDF's are more efficient when they are closer to the exit end of the tube than the intake end. You're testing this one at the actual intake end. Try testing it at different positions within the tube and see if you get better results.
oneiwily on May 25, 2013
nice going guys
Yogenh on February 28, 2014
I like it and are you going to post plans for it? How long did it take to make it
