FTScratchBuild
The Speed Build Kit is available in our web store!
FREE Build Plans:
FT Simple Soarer [ FULL SIZE ]
FT Simple Soarer [ TILED ]
For recommended electronics: Click here
FTScratchBuild
FREE Build Plans:
I would recommend putting the flaps on the throttle stick. Just plug the servo you are using for the flaps into the throttle slot in the receiver, just make shore that when the throttle is on full the flaps are up, and when the throttle is chopped the flaps are down.
I know a lot of the swappables have been run on 2200 3s, could this guy carry the extra weight?
~psguardian
I use a minimal amount of hotglue in the tail and a 650mah Li-Po battery in the nose, 5g servos and this thing flies for ever.
Here is the math. tan 4 = X/36mm X= tan 4/ 36, X = 2.5mm
Really, really nice video on this wonderful glider. I am trying to build it together with my son (8 years old) and hoping it will be the plane for him to learn how to fly RC.
When working out the plans on scale, I noticed that the spars are not drawn on the plans, the length should be the same as the shorter part of the wing on the plan, however the width is not mentioned anywhere (from the video I guess it to be about 1 inch), also the hight is not clear (it appears to be two layers of 5mm foam board). Can anyone confirm this please (ceramic999@gmail.com)?
I am quite possitive the we can complete the glider, the plan and the build video are really good, thanks Josh, keep them comming like this !!!
Greetings Ton.
Mine came out at 320 grams without the battery.
I used 4.8g servos a small UBEC and receiver that weighs 7g
Why was the last hole cut off the servo arm?
Can I make allowances for excessive throws in my transmitter setup?
In case of a tumble, it seems the narrow point of the tail is the point of failure. I lightly glued a skewer along the bottom as a stiffener.
Thanks in advance.
I bought 3 sheets of foam board from Walmart: Elmer's Acid-Free Foam Board, 20" x 30" x 3/16" polystyrene. Is this stuff too heavy? Or did I build it too big? The wings are 29" x 8" each, and weigh 170 grams (just foam - 150 grams for each wing, and 20 more grams for the folded foam support that is inside each wing)
Any guidance would be appreciated! At least I caught the issue before I assemble it.
Not sure you got a reply on this. Never never use Elmers Foam board to build FT planes. They will look fantastic but they won't fly. The Elmer's foam is much too heavy.
The best foam board I've found is Adam's from Dollartree. It is very light, nice and rigid and the paper peels off very easily if needed.
Have fun!
Thanks for sharing.
CG is right under the spar, correct? towards the front of the spar?
The link to the "tiled plan" seems to be broken.
https://www.youtube.com/watch?v=_OqEk0ZNEh4
https://www.youtube.com/watch?v=DIBwbPVzrUo
https://www.youtube.com/watch?v=P66rYyb5N7Y&feature=youtu.be
thankyou in advance
