FTScratchBuild-Advanced
the free plans are available below as well!
If you want to pick up a speed-build kit head on over to the web store! Otherwise, you can download the free plans at the link below.
FREE Build Plans:
FT Mustang [FULL]
FT Mustang [TILED]
Equipment used in this build:
FT Control Horns
NTM Prop Drive Series 28-26A 1200kv / 250w
Hextronic 9 Gram Servo
TURNIGY Plush 25amp Speed Controller
Turnigy 1800mAh 3S 20C Lipo Pack
Linkage Stopper "Speed Clevis"
.81mm piano wire (push rods)
Futaba T8FG Super 14ch Transmitter w/R6208SB 2.4GHz Receiver
Futaba R6106HFC 2.4GHz FASST Mid Range 6Ch Rx
Additional/Alternate components:
Flite Test Combo Flight Packs with everything you need available at www.altitudehobbies.com
Thank you to the entire community for making projects like this possible.
Let us know how your build went or if you have any tips or comments, chat it up in the forums!
I know the untiled plans are suposed to be just that, but with the difference in paper sizes (letter vs A4) im kinda worried that my printout from the tiled plans might be missing a few bits.
Oh well, no choice but to try it out and report on what the results are.
I should really find someone to print my plans for me... all this experimentation is turning me into a tree-killer.
Thanks again for the amazing plane.
I've also seen it on the untiled plans.
Do you guys mind listing the size of the piano wire that was used for the landing gear in the "Equipment used in this build:" list? Thanks for what you guys are doing for this hobby. It's much appreciated!
.8mm is for pushrods, that's right.
The size for the landing gear that Josh mentioned in the Video was 1/10", so round about 2.5mm
This means that the upper surface of the wing is a little shorter that the lower, which results in the desired dihedral.
Other designs, like the duster and the simple soarer rely on smaller cuts, then crushing the top surface foam slightly to get to the needed length for the correct angle to form.
I liked the Mustang, I have the 3 d designed for you and in a few days I will ride the Mustang and it also very cool and fast! like a power visitálos day and know all the hugs fliter atodos test!
The plane looks amazing!
Thanks.
I would apprettiate to have them also in old Tiled plans like FT-3D, FT-Versa, etc.
http://www.hobbyking.com/hobbyking/store/__34108__D2826_10_1400kv_Brushless_Motor_US_Warehouse_.html
I do this all the time to break the plans up into separate parts. e.g. 4 pages for the wing section, 3 pages for the fuselage, etc.
On the other side I can’t see why the grid lines or other marks on the plans can upset anybody. They are just marks on the plans they are not going to stay on the plane. Anyway I think that there more pros than cons. Let’s make a vote shall we :)
When I went there, though the answer was "Yes, we can print your file for you. up to an amazing DIN a3 format!"...
Needless to say I gave em a pat on the back and went home with a packet full of pins and a roll of clear tape.
I'd try it if I had a printer that worked.
1. The obligatory air-to-air combat
2. Running an obstacle course
3. Possibly a pylon race course
As a baseline, each of the three designs should have the same electronics, since the testing is of the airframe design, not the power systems.
The other two P-51 designs I am referencing were done by Filken and Jason Eric Anderson.
But one question: which is the material? depron 3mm?
Thank you for a answer!!
note: i really like long flight times - See more at:
http://www.exceedrc.com/63m15.html
I compared it to this motor below which is recommended:
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=26820&aff=247441
The max current is lower for the Exceed motor and a hair lighter.
depron 3mm???
Doug
It just continues to roll in either direction after aileron stick is returned to central position , very weird, if rolling left and correct back to right back to level flight it continues to roll right, If rolling right and corected left back to level flight it continues to roll left.
Its not a matter of trim, when I do get it to stablize it flies level but as soon as using the ailerons it does what I described
Here is the link of the Motor: http://www.hobbyking.com/hobbyking/store/__18225__Turnigy_D3530_14_1100KV_Brushless_Outrunner_Motor.html
the links of download are corrupted.please add them.
I decided to make this model and I took the model's project.However,I don't know,how many mm will the foamboard? 3mm,4mm or 5mm ?
