FREE PLANS - CORVUX V1
by Jake Wells | November 26, 2014 | (14) Posted in Projects
FPFB250 – Aka:FleshPilot Foam Board 250
FCU(Flight Control Unit) Flip(MultiWii 2.5) - http://witespyquad.gostorego.com/flight-controllers/flip-2-5.html Motors, 4 2300kv - http://witespyquad.gostorego.com/motors/rtf-mini-motor-x2204-2300kv-light.html Motor Speed Controllers - 12 amp ESC's - http://witespyquad.gostorego.com/speed-controllers/readytoflyv-f-12a-fire-red-12-amp-rapidesc-simonk.html Propellers 5 inch - http://witespyquad.gostorego.com/propellers/hq-prop-5x4-fiberglass-composite-prop.htmlAnd of course you need to have a Radio and might want FPV gear, a GoPro and Batteries.
This frame with wood is 193 Grams.
Items you will need to build the FRAME only:
1. Printer.
2. 14 pieces of Paper.
3. 2 full pieces of Foam Board. 20in x 30in x 3/16in.
4. Exacto Blade
5. Hot Glue Gun with Glue sticks
6. 2 pieces of square dowel 1/2in x 8 1/2in.
ATTENTION!! On the body of the fuselage of the plans you will see some long dashed lines. Only cut through ONE side of the foam. I will cover this in the build video.
To download the plans go to FleshPilot.com and click on the FREE PLANS link at the top right of the home page. Or Click here http://www.fleshpilot.com/?page_id=2264
This is how the plans should look when taped together.
BODY
MIDDLE
TOP
All pieces cut
Flesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 TrainerFlesh Pilot Build FPFB250v1 Trainer
Dry fit mock up.
Here is a early pic of the prototype.
applekeith on December 2, 2014
Congrats on the new addition! I would also love more detail and a recommended electronics setup.
Jake Wells on December 10, 2014
Thank you so far I have two of three of the build video's posted.
SGRacer on December 10, 2014
How do you attach the mini quad motor to the wood? Mine did not come with any mounting hardware other than screws.
Oooo good question. What motors do you have?
emax 2204 2300k. The screws that same with it have a really big head, and are not flat at all.
thanks!
order these ...http://store.flitetest.com/simple-motor-mount-discs/
SGRacer on December 1, 2014
Congrats! I would love to see a build video, as this might be the best way for me to enter 250 racers (I built a 450 already). My only concern is that this frame is 50% heavier than other 250 frames, any Idea on how to cut that down?
CartCurt on November 28, 2014
Very interesting design. When can we expect the build video or even pictures and directions? I am wondering what's inside the shell.
Jake Wells on November 28, 2014
Probably not for a week or so. My wife's water broke this morning. Looks like we are having a baby today. There's nothing in the shell. How to run the electronics is up to the person. I cut a small door in the back of the body to slide my battery in and out. I'll cover all of that in the build. Sorry I ran out of time with the holiday and the baby coming early and all.
Congratulations! There is only one thing better than a new baby. It's a new grandbaby.
vontugboat on November 27, 2014
Very cool project. Very cool music as well!
Jake Wells on November 27, 2014
Thank you!
SnapPunchRobert on December 8, 2014
Really Cool Design. I like how the blades are protected so running in to trees or whatever won't end up in tons of broken props.
Really hope to see a build video soon.
Congrats on the new baby. Congrats.
mlutze on January 29, 2015
Jake - Very good work on the build video. I think I know what my project for spring flying will be. Keep up the good work!
