In this episode of Flite Test, Josh Bixler shows us step by step, how to build the Fokker DR1 Triplane! This plane goes together very quick, is cheap to build and also very efficient when in the air. Watch this episode to learn how to build your own.
Designed by "pmjass" from rcgroups.com
Thread: http://www.rcgroups.com/forums/showthread.php?t=305596
PLANS: http://www.rcgroups.com/forums/showthread.php?t=1652858
What we used:
Built with either dollar store foam board, 6mm depron, or foam trifold display board
Motor: Hextronic dt-750
Servos: HXT 9 gram servos (3)
Prop: 11 X 4.7 SF
Battery: Turnigy 1300 mAh 3s
We simplified construction to make this build simple and with as few materials as possible. Intermediate skill level
The kit sat for a few weeks before I could assemble it. I've just completed assembly and will take it up for a test flight soon. I'm concerned though because the delamination is occurring at the joints of the ailerons and rudder. The aileron essentially pushed down at the hinge leaving about an inch wide gap between the paper and the foam core, making the aileron unusable. Sticking with the materials at hand, I used hot glue to put it back together, making sure to not get any glue in the joint itself. We'll see how it goes...
Any other tips for fixing delamination? And, is anyone else having a similar issue?
Just a few thought on your problem.You could thin water base glue and paint it on to seal the paper to the foam or use light coats of spray paint before you assemble the parts.You did not say how big a problem it is.Just the edge or whole sections.
You have a problem i want.we are 8 degrees with snow and ice on the way.Ain't real flying weather here 50 miles north of Philly.I will not fly below 32 degrees that is cold enough.
I will be interested to hear how you make out,It do get hot some parts of the year.
Good Luck.
Thank keep up the great work..You have taught a guy with 30+ years of building stuff a few tricks.
