Fly 2 with 1
by Pedro Albuquerque | December 13, 2015 | (10) Posted in Just Fun
Disclaimer: This fly took place in Lisbon - Portugal.
Please take a moment to check your local regulations if you ever feel tempted to try this at your flying area.
I have accepted a challenge from my flying buddy to try to have a 1 hour fly with my recently built PA Pelican, a variation from the FT Guinea Pig.
During this fly I had a lot of time to think about new challenges and crazy stunts.
An idea ocurred to me, "what if I take my Quad and fly around my plane to get some footage?"
What an awesome idea.
My buddies didn't approve it at first.
To do that I need to be able to switch off my remote to connect it to my PQuad250.
I only have one remote...
So I tried out all that was required to achieve that.
First the RTL mode.
Then it was time to test the radio failsafe function....It worked too.
It was time to prepare my Pquad250, a homemade wood mini Quad, equipped with a Mobius camera and FPV gear (naturally).
Flying the quad with the plane in the air was challenging enough, but once I got in the air I had to face an unexpected new challenge.
Find the plane in mid air.
If you fly FPV, you may be aware that resolution is crap, so it is quite difficult to find an object unless they have very good contrast. As you can see by the picture that is not the case. There are many colours filling the screen. It is easily confused with houses or clouds.
Finally with my buddies' help I could find my own plane.
As I started chasing and circling arrund it, I totally forgot it was my own plane. It was so beautiful flying around it.
Well the dream finished a few seconds later, as someone just started shouting that the plane was flying away.
I don't think you can imagine the feeling, but you can try.
It was pure panic.
I was trapped with my googles on, flying the quad and all of them shouting to me that the plane was flying away.
I landed as fast as I could, but as I landed, the plane had already recovered its course around home position.
It was an Epic moment and most probably a unique one in my flying history.
This proved to be possible, if you are surrounded with the right people. My flying buddies were an essential element of the achievement. Their support and guidance made the task a lot easier and gave me the necessary encouragement.
I leave here the challenge for the FT Crew to repeat this stunt in their most crazy/funny videos, and eventually explain the way only they can, what it takes to do all this.
Thank you to my suport team:
Luis R
Luis G
Miguel S
Paulo C
Carlos F
Hope you can all feel inspired and define your own challenges.
polodu64 on January 1, 2016
Pedro Albuquerque, this might be a dumb question, but how did you manage to do that ?
I mean, what I don't understand is that once you switch your Remote Control back on, to fly your quad, because it is the same radio, you should regain control of your airplane too, and you should be flying the two aircrafts simultaneously, shouldn't you ?...
Pedro Albuquerque on January 1, 2016
Weel Polodu64, that is one of the key point that I was wayting for someone to question me about.You nailed it.
There is a treak here,I am using a Frsky module and I have a non telemtry RX on my plane and a Telemtry one on the quad.
I have to switch from non telemetry to telemetry on TX so that I can talk to the quad instead of the plane. When I do that, the plane cannot undertsand the protocol so is not reacting.
Only because of this it is possible to fly them both with the same radio,as they use diferent protocols.
The same would happen if I switch modules on TX (may 9XRradio allow to swith TX modules) for instance if I used a DMX TX and RX for the quad.
The safest way would be to use two radios,one for the plane and another one for the Quad, so that I would not have to switch off the radio from the plane,although it was flying autonomous most of the time. So in case of missbehavior (as it happened) someone could take control of the plane.
polodu64 on January 2, 2016
Pedro Albuquerque, That is awesome ! I would never had thought of it :-P
Great article and great idea, thanks ! :-)
TimmyGT on January 1, 2016
I know that on my DX6 if I switch models it will terminate the link to the current model and switch to the new model
Szilard on January 4, 2016
One of the craziest thing that someone made, but also, iiimmmmpressive. Well done dude. If you let me, I will make a test like yours :-) Congratulation. :-)
Pedro Albuquerque on January 4, 2016
Hello Szilard, of course that you can try, and please share with us you attempt what ever the result is , because most of all the attempt process if very rich and fun.
Fearless FPV on January 1, 2016
Wow! That's amazing!
Next level is to make 2 planes fly them up in the sky and activate RTL on both but on same route and the one behind would take the shoot of the first one. ALL AUTO :-) Please do it, please :-)
Yes ,that certainly is an interesting idea. I have a few more on my bag planned to execute this year.
steadfast4life on January 1, 2016
I have actually thought of this before since I fly mainly by myself. Thanks for showing it is possible.
Hi steadfast4life, this is a quite risky manuver, so consider having omeone to back you up in case some thing fails. In this fly it did and I was 2 times "lucky", I had people aware that there was a problem there was no way I could detect while flying my Quad, and second the plane recovered on its own and avoid a bad ending.
For the first one you can take precautiony flying with someone nearby, the second one is pure luck and testing the system well before doing something with more risk involved.
Fly safe, and enjoy.
DOOM on January 1, 2016
OMG! Did you really? I would have most certainly wet my pants during that attempt. Respect sir, respect!
Fly 2 with 1
