FTScratchBuild
It's here! The FT Tiny Trainer is finally available and ready for flight. This step-by-step tutorial will show you everything you need to build your FT Tiny Trainer Speed Build Kit.
The speed build kit is available in our online store and the the build plans are available for those of you who want to scratch build this versatile foamboard Mighty Mini.
You'll want to put together your mini power pod first!
More details available in the power pod article here:
http://flitetest.com/articles/mighty-minis-power-pod-build
FREE PLANS
A solid plane starts with a solid fuselage. Always take your time and wait for the glue to dry completely before moving on.
Be sure to have the push rods cross and go out to the control horns without binding along the way.
Both noses feature doublers, to help reinforce and strengthen the plane for any situation. With this, a beginner should be able to take a few hits and continue flying, if they didn't break a prop of course.
Be gentle when forming your wing. You shouldn't have to force it to much, and be patient with the glue.
Use some spare wire to feed the servos through the wing after its closed up.
You can create your own Z-Bends with a pair of Z-Bend Pliers: Available Here!
With the plane nearly done, all thats left is strapping the wing down, and testing your controls.
We can't wait to see how your FT Tiny Trainer build turns out!
Be sure to share with photos, articles and comments!  Thank you for all of your support and input with speed build kits like this!
Let us know what you'd like to see as a speed build kit!
The FT Tiny Trainer is part of our Mighty Minis Series and are powered with our Power Pack A (Minis) electronics setup available in our online store!
New to the R/C hobby?
Here's some resources to help get you up to speed!
Beginner Series: WATCH HERE!
Electronics Setup: WATCH HERE!
First Flight Quick Tips: WATCH HERE!
Got glue?? Get Some Here!
FREE PLANS
Learn more about the FT Tiny Trainer here: SPECS AND OTHER DETAILS!
Great work, guys! Thanks for the wonderful toy for my kids. Good Luck, and Have Fun!
Thank You Flite Test:))
This is another great design and as usual flays great too :)
Thank you so much for what you are doing, keep on the great work you are doing, you are truly awesome!
Best way is to use Full Plan and select Poster in print options, that will print as tiled on whatever paper you are using.
Thanks again for everything you guys do for the RC community.
-Matt-
2208/8 2600kvc ESC-30A
Prop:EP-6030 or EP-5030
20-30C,1600MAH 3CELL 11.1V LI-PO BATTERY
You can fly a brick if you get the "CG" right and keep it together. That's what makes it fun.
originally I wanted to build a Mini Scout and therefore got an Emax 1804 2480kV with TGS Sport 6x3E propellers @ 3S. Will it be OK for a 4Chan Tiny Trainer?
Thanks,
Paul
Nearly finished building it from 6mm Depron :)
my favorite is the "disposable "foamie motor/ESC deal for $20.00!!
I can fly all the minis with them.
Wingspan - 37 inches (940 mm)
I just completed the glider version of my tiny trainer scratch build and I am having a little trouble balancing it. As I am still waiting on my batteries I went out today just using it as a chuck glider. The total weight (with servos) is 270 grams. In order to balance it properly I had to put 90 grams of dead weight right in the nose increasing the weight to a total of 360 grams.
Now the battery that I orderd weighs in at about 30 grams and the ESC another 10 grams which means that when I put them in the nose I would still be 50 grams short of balancing the plane.
What is the wheight of your planes? Can any of you confirm the weight given in the build plans of about 200 grams without battery? How did you balance your planes?
Any ideas of how I could properly balance my plane without increasing weigth drasticaly? I was thinking of building a longer version of the glider nose. Would that have a big impact on flying characteristics?
I would be very greatful for any advice!!!
Greets
Andy
Also: At it again with the di/poly eh? ;-) Dihedral mate! Not POLY; There's only two angle changes: Di; hence dihedral gauge! Poly would be dihedral at the centre of the wing and then another bend up at the tips for example....
I like when you guys do a team build. I find it very entertaining. I know we can't always have the comedy styling of a pseudo celebrity like Josh Scott ;-) but one of the other Flite test guys or gals would be good.
Love it! I think you are copying my design! The TUT-1, The Ultimate Trainer - 1!
I thank you for getting me back in the hobby after 20 years!! Flying today was like I remembered but even better! I maidened my tiny trainer today and it is AWESOME!! After a learning curve and crashing my FT Mini Speedster. That same day I crashed you released the tiny trainer and that night I began building the tiny trainer which got me flying today through 4 full batteries.
Very forgiving and fun plane even with 3 channels and poly wing. High rates recommended for windy conditions.
Motor Emax 1806 1430kv
Prop APC 6X4E
Esc Emax 12A Simon K
Turnigy 800 mah 40C 3s 3 cell
12 minute flight with 37% charge remaining. I cant wait to buy a 1000 mah. I tried to fit my 1300 mah 3s but it wont work.
Flite Test You ROCK!!
Thank await response, RinacioPT
- try and visit your closes RC Flying club and speak to flyers there. If you have never flown before you may want to consider having help not only to save you frustration but also to guide you on safety.
- I use the FrSky Taranis which is not cheap but once purchased it may be the only one you ever purchase so in the long run cheaper.
- Orange Tx & Rx from Hobby King. A club member uses it. He also happens to be a real plan pilot instructor:)
I really like your build videos. Josh does an excellent job of explaining things and demonstrates a lot of patience. I noticed something in this one that you hadn't explained before and I don't think you got it quite right. A dihedral is defined as an angle formed by two planar (flat) surfaces. A polyhedral is a shape formed by more than two planar (flat) surfaces. I had never heard the expression poly-dihedral. In my experience it is either flat, dihedral, or polyhedral when talking about wings. I might be wrong on that point, but that is the way we say it where I live.
any news about the "FT Foam" ????
Cobra 2204/2300kv
Castle creations 15A
9g servos
Tactic Radios
Mark Twain Hobby... Local Hobby Store
What was the total weight of your model with battery and all other stuff?
I've built 22 of your planes and has bin a great learning experience.
Question on tiny trainer, then you rubber band the wing on, it warps the wing, should-en there be a notch for the wing to fit in?
I had to tape a couple of quarters to the end of the tail to get it to balance with the 72-gram 3-cell 850 mAh batteries that I use in my T-Rex 250.
I very quickly went from 66% throttle travel to full throttle travel and low throws to full throws. I'm a complete noob flying planes but an experienced heli guy, so I'm picking it up pretty fast. Tonight I'm building the advance wing, and next week I think I'm going to build the glider wing. It would be fun to build the Bixler version too. Really fun design guys. Great job.
I experimented with an APC 6x4e prop that uses 20% more power. It's more rigid and doesn't resonate (howl/whine) at full throttle.
Mine was the cheapest airplane at the field by a long shot, but I'm sure I was having the most fun. :)
From all the video's I watched I learned that everyone crashes, so I wasn't put off by that.
I didn't have anyone to film my maiden flight but for a Very First Timer I was happy with the result. The plane flew fairly well, considering I scratchbuild it from tiled plans.
- Scratchbuild it: - 1 weekend
- Used the FT Powerpack A + a 3cell battery (little havier then the 2 cell)
- Crashed it: - about 5 times
- Flew it: about 15 min airtime (I ran out of propellors)
The crashes, mainly caused by my inexperience cost me 2 propellors and did some damage to the plane. There are a few things I can say about this experience.
The Trainer is the perfect plane to begin with If you have no experience whatsoever.
I did build both wings (glider and aileron) but I started with the gliderwing and will stick to those 3 channels (throttle, rudder and elevator) for now untill I have more experience and break less (none) props.
As far as the design/build is concerned I recommend a few reinforcements.
Although the rubberbands take a major load out of the hit during a crash (cartwheel)
they didnt prevent the foamboard from ripping at the attachment points (BBQ sqewers). Upon carefull examination of the entire airplane these are the mayor points I need to reinforce. Ill be using old creditcards for that. Also, even though the FT team shows this in other build video's but not in this one, Ill be covering ALL the exposed foam (edges) with glue or tape, avoiding the paper to come off the foam board.
It was too windy, but I flew anyway. It flew great, but the wind was a problem. Not sure how windy, but I could 'hover' by pointing into the wind at about 50% throttle. Wind cause a couple of crashes, and I had one graceful landing. Damaged powerpod, which I didn't reinforce with tape. Easy enough to make a new one of those.
this weekend i'd maiden my ft tiny trainer!! it was a blast... BUT...
The cg was way ahead and i had to put way too weight on the back to compensate... but it flew anyways... and it crashed too... but that was due to my persistence to fly it without low rates!
It was fun tough! i'm back to the work bench and will use the wing and the tail to maybe do a frankenplane!
very durable , these children range from 12 to 3 yrs old's, flies great! it took a beating from the kids trying to see who could get the longest flight. Added 3oz of weight to the body and got longer flight. balance the plane before flight.
I really like the way you have provide us the video and stuff to build for new-comer like but as you know those part which I see are hard to get special the exact specifications like i saw we servo of 9g but the main question come where I can get frame kits
I have dream to build myself even if it's the simple trainer model I saw the structural pdf for the plane but I don't know to even to put layout on simple foam.It would helpful provide some information on it. Like for example the foam as in India find dollar tree foam is hard.
Thank you
Zaid Malik
Flying high is my dream..
I've scratch build mine FT trainer out of depron foam covered with tape and I have a problem.
I'm using the glider nose together with the rudder and elevator controls and no matter what I do my plane refuses to fly straight (always turning to the right). Only with my rudder stick fully to the left flies straight. As far as I can tell every surface is straight and level.
Please help me, all tips are welcome.
Mike
Until now i didn't relaunch it, but i will be soon. Still waiting for new props :)
50x70cm
70x100cm
100x140cm
How many and wich ones I need to build it?
good or bad idea
i am new to this hobby
which type of foam is used for building
Styrofoam or Depronfoam ??
thank you
Just come in from its maiden voyage with the sport wing and ailerons - boy does this design flatter newbie pilots!
Managed a few rolls and loops and even managed a hand catch The people that were at the field were blown away that is was made from laminate floor insulation sticky tape and hotglue and could fly so nicely in the hands of a newbie pilot
Mini arrow plans printed off and waiting for a free moment to get cutting and gluing!
Thanks once again - keep up this great work!
Fantastic design that flies waaay beyond my expectations
Mrs did video some of it - will try and upload and post a link to it (assuming a plane can be seen when we download and watch it) :D
i would really appreciate it if anyone recommended any other batteries that will give good flight times with the trainer and not from banggood or aliexpress as weve had very bad experiences with them in the past. thanks
