Easy Swappable Air Hogs chuck glider.
by tmask32 | June 17, 2013 | (16) Posted in Projects
   This is not the first r/c conversion but may be the first Swappable Air Hogs r/c conv.. You can build this in one afternoon easily and is a blast to fly. And uses a power pod from one of the FT Swapables.  The Air Hogs titan glider is a well built $10 chuck glider sold a Walmart and Target. Just as a glider alone it will fly a good 75yds. The foam is fairly durable and takes low temp hot glue without a problem.
   In flight:  On a tiny 1300kv 24g motor the titan cruises around at half throttle effortlessly and at wot will climb and flip with a little work. The stall speed is low so great for small parks.
Build: As you can see I cut out, sanded and notched out the whole bottom front of the plane to fit the power pod. Added BBQ skews in the front and rear to lock it all in. Two 9gr servos for elev and rudder. I used scrap foam board for the control surfaces. And I put clear shipping tape on the leading and trailing edges to stiffen everything up. I opted not to glue the main wings as the will snap if it takes a good dirt nap. C/G is about 1/3 from the front of the wing cord. I had to use two pennies in the tail to get a good balance.
Specs: Hextronic 24g 1300kv motor
           18amp plush speed control
            500mah zippy lipo =10min flight
            8x6 SF apc prop
            2x Hextronic 9r servos
Thanks for reading, If you build this you wont regret it, its a blast and easy to fly, ask my 8yr old son.
Any questions or if I missed something don't hesitate to ask.
Cheers.
llharper on June 21, 2013
Great idea. I wouldn't change a thing. Your camera man did a GREAT job keeping up with the plane!!
tmask32 on June 21, 2013
That was my 8yr old son and his first time filming an airplane. He will be so happy to read your comment . Thanks
earthsciteach on June 18, 2013
Really simple and clever. I have a couple of chuck gliders I may make a pod for as you have done. Thanks for the idea!
craftydan on June 18, 2013
Tmask,
Picked one up this evening, and plane glides well with a stock CG at ~2/3 cord from the root LE. Seemed far back to me, but it does have a strong back sweep.
How's yours handling at 1/3? I'd hate to go though all the trouble of mounting parts only to need add weight farther back.
Also, are you running 2 or 3 cell?
tmask32 on June 19, 2013
craftydan, I am running a 3cell, all the way to the back of the power pod. I've found if I dont use the landing gear and put two pennies in the tail it flys gr8. It is a little nose heavy though. So you are right, I just never checked the cg before i built it ,so it was a guessing game for me. But I bet if you put the battery right behind the power pod it might balance out even better. cheers
craftydan on June 19, 2013
TMask,
I embedded a 3s 1000 just behind the stock CG, bringing it back to between 1/2 and 2/3 cord. Glide tests were still a touch nose heavy, but better than without the battery. Control surfaces and servo mount similar and I'm using the turnigy brand of the same motor w/ a 8x4.3 prop (tested at 390g thrust). AUW is 425g.
Had to build an extension cord and carve on foam, but moving the battery backwards did help on glide. Not that you'd trust it after you hear about the maiden.
Not sure if I'm fighting trim, excessive throttle, or just plane noob-ness, but on maiden, it had a wicked roll. Maybe the touch of left thrust angle was way too gentle. Either way, between another broken prop and setting sun, I'm back to licking my wounds (and considering ailerons).
I am trying to upload a vid now so u can see how she flys.I didnt have any problems with roll , actually it flew almost without any trim. I can tell u that I did not use any thrust angle, and the power pod is parallel to the other horizontal surfaces. Maybe its because I used a 500mah battery. If there is any measurments ypu need or more pictures , let me know. Good luck, Oh also I tried a 7x5e prop and it was a lot faster.
craftydan on June 20, 2013
Tried again, and well, better, sorta.
My rudder is anemic (~2in -- needs more!), coupled w/ WOT, it spun on the prop and rudder couldn't correct. Dropped a size on the prop (7x3.5) and reduced throttle to a tick above 1/2. still couldn't turn well, but elev (also ~2in) was strong. no problem turning via Immelman -- it rolls easy to self correct.
unfortunately met with the ground one too many times:
http://forum.flitetest.com/showthread.php?4447-What-s-on-Your-Mind-Feel-free-to-discuss-amongst-yourselves&p=52432&viewfull=1#post52432
Now to find my gorilla glue and packing tape . . .
RoyBro on June 18, 2013
Nice conversion. I'd love to see how she flies.
Auw I got is 432 grams
cool refit
What was your final AUW?
Gryf on June 19, 2013
What a cool idea! Mounting the swappable pod with an existing airframe opens up all kinds of possibilities.
slav on June 18, 2013
any vids???
tmask32 on June 18, 2013
Thanks for all the great feed back , i'll try to get a vid of it on wednesday. And i will check the weight as well.
TheRedBaron on June 18, 2013
Awesome thats all I can say I hope to see a video
lracnolip on June 20, 2013
cool idea mounting a swappable, wish I saw this yesterday as I just finished digging out the foam and building it with ailerons and no rudder and some bixlar wheels for touch and go's. Just did a test flight and it flys great, not bad for $10.
tmask32 on June 20, 2013
Thats gr8, would like to see your aileron setup.
jack111 on July 11, 2013
that was great and the camera man actually stayed on the plane i would have not been able to do that super cool!
Captain Crash on February 10, 2014
is that the titan
tmask32 on February 11, 2014
Yes it is .
