The E-Flite Convergence VTOL (vertical take off and landing) was fun and exciting to fly. We were impressed by several of the features it includes such as the auto level capability, the ease of transitioning from stability mode to acro mode, and of course, the fact that it takes off and lands vertically.
Our thoughts
- Auto level makes it crazy stable.
- The forward and backward motion keeps the aircraft flat and only changes the thrust angle of the motors in the front.
- Banking is done through differential thrust in hover mode.
- With the flip of a switch, you can transition from VTOL to full aircraft mode. The nose drops when you switch modes from horizon to acro, so make sure your speed is up when you transition.
- Make sure you take your time when you switch to advanced mode.
- It feels good to fly the Convergence. It’s very natural. Docile.
- It works off of 2200mah 3-cell battery, which most people have and is affordable—we were able to get a decent amount of flight time off of it (approximately seven minutes or a little more).
- The Convergence is not necessarily a beginner plane. If you can fly a 4-channel plane, you will easily be able to transition to flying the Convergence VTOL.
- Make sure you memorize what each mode does so you’re not surprised mid-flight
- Always transition into the wind.
Features
- Has FPV capability.
- Multirotor and sport plane capabilities.
- Auto leveling.
- Powerful brushless motor system.
- Stability and acro modes.
Get your own E-Flite Convergence VTOL here!
Have any of you flown the E-Flite Convergence VTOL yet? Share some of your thoughts or favorite aspects of this versatile plane!
