DIY Tigrish FPV Project !
by val0production | December 29, 2013 | (10) Posted in Projects
Hey it's me Val0modelisme ! The French Man ! and today i want to present you my new FPV project : The Tigrish !
I created the Tigrish for to fly slow and stable with HD Cam !
Specifications :
Wingspan : 1260mm
Lenght : 1030mm
Weight : 990grs Ready to Fly with FPV system !
Clark Y profil and double dihedral
Full Depron (3 & 6mm Foam)
Equipment :
Motor : Turnigy Aerodrive D2830 1000kv
ESC : Turnigy Plush 30A
Lipo : Turnigy 20C 3s 1300mAh ------> autonomy = 8min       ;    but it can fly easy with 2600mAh !
Servos : 2x HTX900 9grs
Receiver : 2.4Ghz HK 6Ch
FPV Equipment :
Tx : 900MHz 800mW
Camera : PAL Cam
Antenna : ''IBCrazy BlueBeam'' or ''rubber duck''
HD Recorder : GoPro Hero 3 Silver
France     Haute-Savoie    Alpes
 Evian factory {water}
If you want see the flight : Watch from half of the video
fl_rider on December 29, 2013
Cool plane!! The countryside is beautiful. Thank you for sharing.
Chris
val0production on December 29, 2013
Thanks !
alibopo on December 31, 2013
Tres bon - nice design! Very stable flight video - so clearly a success.
Observations... I notice you have not inclined the motor to change the thrust angle. My build of the "Smash Drone", a similar foam board pusher design by Cstence, flew MUCH better after I changed the thrust angle. Before the change - when I applied throttle the plane went 'dead' and was reluctant to climb. After the change - the plane was much more responsive and flew very freely. I'm sure the flight times were better as well.
See my logic in these articles;
http://www.flitetest.com/articles/find-your-centre-of-gravity
(At the end you will see the Smash Drone and how I decided on a new thrust angle.)
http://www.flitetest.com/articles/yes-it-s-a-smash-drone
(Explanation of changes , plus before and after video showing modifications to design and performance improvements.)
On your plane I would find the TRUE CG and then direct the motor thrust through a point a little above it (1-1.5cm?) - to allow some of the thrust to counter the additional drag force that comes from the wing when the throttle is increased. I think you can change the thrust angle easily with a few washers under the bottom two mounting arms on the motor. JUST a suggestion though :)
Can I ask what your AUW is with the 1300mah & 2600 (2x1300?)mah battery?
Cheers, alibopo.
val0production on December 31, 2013
Thanks !
I know for the thrust angle it's not good...
Thanks for the advice !
But i don't understand : What is the ''AUW'' I don't know this word in english xD ?!
Hi - apologies for the confusion.
The - AUW - stands for "All Up Weight". What does the plane weigh (grammes) when it is ready for flight with a full payload of batteries, camera and FPV gear?
It would help me compare it to my Smash Drone - 950 gm (with 2000mah LiPo)
Thanks, good flying :)
Ah ok, yes it's 990grs ready to fly with all FPV system !!! (With 3s 1300mAh ---> 10min of flight today !)
ankit dhama on January 13, 2014
Great job nice and which cam you using what is prize of the cam and great going keep it up
Hey and which material you use for wings
val0production on January 13, 2014
fpv cam ?! ---> it's a basic from HobbyKing (~16$) {1/3-inch CCD Camera PAL 520TVL}, the quality is pretty bad for details but for begin it's good...
For the wing i use just 3mm Foam (Depron)...
ankit dhama on January 14, 2014
Oh nice hey I make a plane same moter that you have I am new in hobby what should do starting hand throw or by wheels my starting hand throw goes wrong tel me some tips so it go on air up them I can control please
val0production on January 14, 2014
Euhh i don't ready know if i don't have picture...
i think is better to ask on the forum of Flitetest...
giokat on January 15, 2014
Beautiful plane, and beautiful places!
What place in France is that? I visited France some years ago, but just Paris and Loire (Amboise).....
Cheers
Giorgio
val0production on January 15, 2014
Thanks !
Captain Crash on January 22, 2014
i love this idea but i don't understand french
ooboob on February 2, 2014
Hi,
I'm happy to join your community. This is a great plane so I am wondering if any pdf plans are available.
Sorry if I missed out links that might have been posted in that regard :)
Cheers !
val0production on February 2, 2014
Hi thanks !!!
For now i don't have the time for draw the plan but i think it's for soon !
val0
nickw on August 27, 2015
When will plans be available? I really like your plans.
Thank you in advance for your reply.
Frank
