This is a pusher version of my Delta Wing design. All of the same dimensions, except the root chord has been moved up a 1/2 inch. Flies great!
Wing span: 30 inches
Root chord: 11 inches
Tip chord (including 2 inches of elevon): 9 inches
Sweep: 11 inches
Motor: 1300 kV blue wonder
Prop: 8x4
ESC: 18A
Receiver: Orange Rx
Battery: 1300 mAh 11.1V 3S lipo
Servos: T-Pro 9 gram
Center of Gravity = 7 inches from nose
Supplies:
1 x 30" x 20" foamboard sheet
1 x 30" x 15" 1/2 inch pink foam
Strapping tape
Hot glue
Popsicle sticks
Control horns/push rods
Motor with mounting system
Velcro
I have a Spektrum DX6i.
I did a write-up on my blog:
http://miracleair.blogspot.com/
Thank you SO MUCH for this excellent design. This has to be the most underrated video on Flitetest. 5 stars! Wish I could give it 6!
