Cutting dollar tree foam with high pressure water
by Pumpster | March 19, 2014 | (9) Posted in Tips
Good afternoon from (I hope) thawing Michigan! I wanted to put together and a quick article on how I have been cutting out the FT planes for myself and club members and anyone else who wants to give or hobby a try. I wanted a good way to cut foam planes out consistently and quickly so people that wanted to get into the hobby could have fun and see what this is all about, the good and the bad.. With several years (just about 30) of building and flying planes of all shapes and sizes, I’ve had my share of the “bad”. After the loss of a few giant scales; one being a Hosteller 33% Edge scratch build; I wanted a hassle free plane to place in front of a potential flier and try it out. I found the Versa Wing to be that plane for the guy that wants to try RC flying out.
I’m a robot programmer; one part of my job is to program robots to cut out prototype parts for the auto industry in and wide range of materials. One day I was curious to see what would happen if I cut dollar tree foam with the water jet.. I knew at a water pressure of 50,000PSI it was going to cut just fine, but I wanted to see how wet the paper would get. It all worked out very well; the water passes right through the paper and does not get wet. The other thing that I liked was the cut was strait and clean. So I sat down with Sketchup and designed a simple fixture to place the foam sheets on and started programming with the consent of my boss which wanted me to build a plane for him lol
I’ve cut a few for club members and others folks that want to fly. I’m also interested in cutting out some simple planes for my local schools to show parents, kids, and staff about the hobby, similar to what flitetest did in one of their episodes. Maybe something that can be powered by rubber band at first then made RC later so the student has a good understanding and pride about something they built.. Like Josh say’s “making memories”
Todd
 AKA “pumpster”
rockets4kids on April 2, 2014
Have you tried increasing the speed to see just how fast you can cut through the foam?
Pumpster on April 2, 2014
I can cut at 2000mm per second without any issues cutting the foam. I haven't had a need to move that fast but when I get a chance I will speed it up to improve cycle time.
Balu on April 2, 2014
Now that's an interesting method I would not have thought of. Laser has the problem of heating the foam so it results in undercuts. Cutting with a blade makes the blade dull quite fast, also you need to make some cuts longer because of the angled blade. Using a router might give wider cuts than required?
This gives straight cuts and doesn't use a toll that needs to be replaced. Love the idea.
It still looks a little frayed / wet at the bottom though?
What is the material the foamboard is laying on?
"Using a router might give wider cuts than required?"
- I would this a router give a wider cut but you can get small cutters that would work well..
"It still looks a little frayed / wet at the bottom though?"
- Their is a little "fray" on the bottom but that's because the cutting tip did need to be replace when I cut those... A light touch some sandpaper cleans that right up...
"What is the material the foamboard is laying on?"
- It's a raw fiberboard material that's formed in high temp press mold.
Phatjax on April 5, 2014
Gonna have to try this with the Waterjet at Local Motors!
Pumpster on April 7, 2014
Nice!! Let me know how it works out for you.
kkuenzel on April 8, 2014
I'm interested! where abouts in Michigan are you at?
Pumpster on April 8, 2014
I'm in Port Huron and I work in Chesterfield.
kkuenzel on April 9, 2014
Sounds like a long way from Kalamazoo!
Pumpster on April 10, 2014
Its is, but if you make it out this way and wanna fly, just let me know..
Yogenh on April 10, 2014
is that in va? I am in midlothiam va
Pumpster on April 11, 2014
That's in Michigan :)
Yogenh on April 11, 2014
Oh there is a chesterfield right next to me in Va.
drbohlen on May 2, 2014
Nice, I work in Allen Park.
SnapPunchRobert on April 9, 2014
So cool. Wish you were in my neck of the woods. That is some set-up. The parts look great.
Thats pretty cool!
PropSpinner on April 23, 2015
I have a friend who cut some depron models like that. If I pay for the foam he cuts it. He cuts materials, manufactured where he works, so they will fit in the machine that measures their tensile and shear strength.
