Credit Card Motor Mount Nutball & Snowball
by Bellows | February 9, 2014 | (0) Posted in How To
Hi Flyers, I am trying to make a slow flying Nutball for indoor fun during this cold snowy winter we are having in New York, USA. I have built a couple of FT Nutballs and learned to fly somewhat using them outdoors in a hay field. Thank you very much Flite Test. They are too fast for my indoor skills. In an attempt to fly in a gym I built a mini nutball with an 11 gram outrunner. It flew well but was still too fast for indoors. I was using the walls and way too often. The last straw was I damaged a fellow flyers Night Vapor in an unplanned attack (it was on a table near the flight line). I am attempting to built the full size FT Nutball without the powerpod to decrease weight and wing loading. The problem is the motor mount. I think this is a good solution. First I cut a credit card in half and bent the ends 90 degrees
 Motor mount first built on a piece of scrap dollar tree foam.
 Here it is ready to be installed on my Nutball wing.
Here it is finished mounted on the wing. There is a layer of extreme packing tape wrapped around the wing from top , across leading edge and around to the bottom. Then the credit card is taped on top of it. This will make removal much easier by not ripping the paper.
Landing gear was made out of control rod material (.047) to reduce weight. Simply bend two 90 degree angles and push through holes drilled through the credit cards.
On the bottom of the wing spread out the wire until you have the desired angle. It will auto matically lock everything in place. Very sturdy installation!!
Alas the wire was too small to fit my wheels properly. I just stripped some yellow insulation off from some wire that fit very snug on the axle.A couple of credit card squres hot glued onto the axle completed the installation.
I haven't maidened my Nutball yet because it is snowing outside and the gym doesn't open until Tuesday. The servos are mounted very forward to help with CG. It is still tail heavy with my light battery. I am sure to learn something from the first flight.
Well.. I did fly this baby but it was tail heavy with the small battery. I flew all right with a much larger battery but was then too fast for my indoor venue.. The motor mount design proved valuable however. I adapted it to the recent Nutball to Snowball conversion. I simply removed the landing gear and cut the tape holding the credit card motor mount. It was them a simple job to build the Float-Skis and add the new motor pylon which I also adapted to the credit card mount. This solved the tail havy problem and I can fly it outdoors in my back yard. Now my Snoball flys with an 11g motor. And fly it does. It is for sure underpowered but it works and is slow enough for this unskilled pilot
 Because the motor is so small I decided NOT to use the plans wooden motor mount. Instead I put in a small shelf of foam and fastened the credit card motor mount to it. This is a win win for me. I flew it several times today off of snow and did not put it in a tree once!!
alibopo on March 25, 2014
Very neat! I like this kind of creative engineering :) AND you lose the weight of any kind of 'swappable pod'. The only weakness I can see is the right angle bend opening up or closing and changing the thrust angle (though it is probably pretty stiff). To combat that possible movement you could 'tab' the sides and fold them back so that you create a little fillet/web to reinforce the fold you already have. Four little side fillets (2 on top, 2 underneath) would prevent any flexing of the motor mount. Also, knowing how tough (within limits) the credit card material is, and remembering that this is a lighter indoor model, I wonder if you could also eliminate the plywood mount panel. Instead of cutting off your waste credit card material above the existing ply mount, what about folding it over. Do that on both top and bottom (one at a time) and you have a 3-layer sandwich of credit card material. Once the screws go through all 3 layers the whole thing will become pretty solid. A little squish of Gorilla CA would seal the deal!
Bellows on March 26, 2014
Thank you for your suggestions. This set up is VERY stiff. I had used some other methods to attach motors using just the foam and movement you speak of was bad. This however is stiffer than the foam which it is attached to. Part of the reason this works though IS because the plywood is so stiff. It was a pleasure to just cut the tape and take it off one plane and put it on another. It turned out the 11g motor was too weak to power it properly. Oh well....live and learn. Thanks for your input!
