You could stream the HD signal to an HD TV or fly FPV with a pair of Headplay HD FPV Goggles.
Check out GetFPV.com for more information on the Connex HD Video Downlink!
All three perform fairly well with 5.8 being the lowest quality but the fastest transmission. The Connex was extremely fast but had some discernible latency. It appeared to be somewhere in-between the 5.8 signal and the Lightbridge signal. Latency on both the 5.8 and the Connex system is most likely due to the GoPro processing the signal, not the signal speed itself.
This custom HDMI cable is a great solution for a gymbol setup!
Big thanks to GetFPV.com for sending us a unit to test!
Which one had the best video quality that could be used for
live streaming?
